Question about BenQ FP71G 17" LCD Monitor
Benq FP71G LCD Monitor - Can't keep POWER ON / Button Problem?
Monitor: Benq FP71G LCD
The monitor appears physically fine but when i go to power it on, it turns on (the green light appears) but after half a second the monitor powers itself off. Nothing is ever displayed on the monitor no doubt because there is no time for it to appear.
Any ideas what is going on? All i've done is switch the power cable and VGA cable but still the same affect. I'm using Windows XP Pro SP2 and have tried the monitor on different PCs and have tried it unattached to a PC.
  • 7 more comments
  • gordz Nov 02, 2008
    Mine has the same sort of problem. The BenQ splash screen displays very briefly then it powers off. Checked for dry/bad joints and all is OK. What next ?
  • nomade1999 Nov 02, 2008
    Same problem here, turn on and sometimes works for few minutes/hours, but most of the time, it LCD will go black but power button stay green. Then cycling the power bring it back for few seconds and it goes black again.
    Very rarely I manage to keep it on for longer.
  • Anonymous Nov 07, 2008
    Same here.
    How do I get it repaired, and is it worth it.
  • lermontov Dec 10, 2008
    Hello, the same problem. I bought my monitor before 2,5 years. The problem occured 2 weeks ago an the monitor worked sometimes. Now I see only "BENQ" with the blue screen for 2 second. I checked all capacitors in the "left" board. If i cut the high-voltage part the monitor keeps powered "ON" the LED is lightening, but of course no image on the screen.
  • Anonymous Dec 11, 2008
    help! :( same problem!
  • Clint Mundt Dec 17, 2008
    Same issue, once you turn the power on the green LED comes on but screen is black or it will power up very briefly and then go black.
  • Anonymous Jan 13, 2009
    mine will let you use it for a while and then turns itself off, the green light goes out and you have to turn it on again, only to get a short while before it turns itself off again
  • Anonymous Jan 22, 2009
    Has anyone fixed this?
    Does anyone know a price or timeframe?
  • Prabhuchandu Kanaparthi
    Monitor: Benq FP71G LCD The monitor appears physically fine but when i go to power it on, it turns on (the green light appears) but after half a second the monitor powers itself off. Nothing is ever displayed on the monitor no doubt because there is no time for it to appear. Any ideas what is going on? All i've done is switch the power cable and VGA cable but still the same affect. I'm using Windows XP Pro SP2 and have tried the monitor on different PCs and have tried it unattached to a PC.
Benq fp71g no display what can i do
Posted on Jul 01, 2011
I solved the problem 4 times, with SC5707. It worked only two days. After 2 days I replaced SC5707 again and so 4 times. At least Isoldered most of all high voltage pins an it works now about 2 weeks! Thanks! SC5707 also!
Posted on Jan 23, 2009
I had the same problem and found that Q808, Q809 and Q805 had failed and which if left long enough can also cause PF801 to fail. I also replaced all of the electrolytic capacitors during the rebuild as it was only a few dollars to do so.
Although in my case Q815, Q816 and Q812 were fine I suspect that they may also fail in time.
Here are the parts which should be available at most electronic stores or online.
Q808 & Q809 - 2SC5707
Q805 - IRFU9024N
PF801 - 3 AMP PICO FUSE
Posted on Jan 22, 2009
  • 105 Answers
Shorted transistors and bad solder joints.
Monitor Mike
Posted on Oct 22, 2008
This problem is caused by the computer changing display modes so often during boot-up. This causes the backlight inverter to rapidly switch on and off. This eventually causes one or more of the 2SC5707 transistors to short. Changing the shorted ones doesn't fixthe problem unless you prevent it from seeing all the mode changes during POST. Many BIOS setups have an option to hide most of this behaviour. That might be enough. Otherwise, a solution is to leave the monitor turned off until the desktop appears.
Posted on Mar 27, 2013
Q7T4-fp71g BENQ monitor picture come and go.power on.thanks.
try it in another coputer if not work you need mantinace eng
Mar 25, 2011 | BenQ FP71G 17" LCD Monitor
Where can I buy a logic PCB for FP71G Benq
Shenzhen VIIV Technology Co., Ltd is an expert at PCB,PCBA and Rigid Borad manufacturer based in shenzhen China.
MSN:viivtech@msn.cn
Yahoo: viivtechavril
SKYPE: viivtech
Mobile: 86)15989403359
Email:avril@szviivtech.com ,zhwei930@163.com
Website :www.szviivtech.com
Tel: 0086 755-29477736
Fax: 0086 755-29410695
ADD: sha
Jul 13, 2010 | BenQ FP71G 17" LCD Monitor
I have a BenQ FP71G+ monitor and the auto adjust message pops up frequently and the screen adjusts itself.
radioactivet, A qualified technician will need to investigate the units "switch-mode-power-supply" for typical "faults" and locate the faulty (bad) component(s) that ma be causing monitor to act this way. "Noise" on the +5 volt DC rail going to the vga/lcd interface (processor) may be why display is acting "strange" with uncalled for pop-up's appearing!! That's the very first place I would investigate when dealing with ANY COLD-CATHODE-FLUORESCENT-LAMP, BACK-LIT LCD DISPLAY. 12fixlouie
May 31, 2010 | BenQ FP71G 17" LCD Monitor
Benq 567s lcd monitor does not power up. Switch led blinks but goes dead. Tried replacing capacitor 450v 82uf with 400v 100 uf but did not work. please help.
That cap is for the Primary power supply switching circuits. How is the DC secondary side, no blown fuse, shorted transistors in the inverter circuits? Pictures will help, budmrtn@aol.com
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
It may have the same bd as DELL since BenQ makes monitors for DELL and HP.
May 21, 2010 | BenQ FP71G 17" LCD Monitor
Lcd monitor BenQ fp71g screen doesnt come on when i hit the power button you can hear a click sound and the green power light comes on but then goes off modelq7t4
Hello
Parts (probably capacitors) in the monitor power supply are failing. My company repairs these for an average of $50.00 + parts + shipping or take it to a local repairman.
Jul 28, 2009 | Computers & Internet
FP71G+ faulty buttons
Normally Benq has a 3year warranty and no warranty card,the serial no consists of date of manufacture.Contact local service centre in your country.
Samir
Aug 23, 2008 | BenQ FP71G 17" LCD Monitor
Benq Q7T3 Monitor fails on startup
Hi...there,
So, this Q7T3 LCD Monitor have a power brick (AC Adapter)??? If yes, check to see if it still lite green. If no, then your backlight inverter need to replaced or repaired. Have a nice day!
Aug 16, 2008 | BenQ FP71G 17" LCD Monitor
Benq screen shuts down when pc is plugged in
If it's a 71g and not 71g+ resolder transistors 2sc5707 on invertor board along with grey condensers and inverter transformer.This should solve the problem if it was display shutting off with power led remaining on.Otherwise check power section.
Feb 24, 2008 | BenQ FP71G 17" LCD Monitor
Benq FP71G+S NOt starting.
Hello
I have had this problem twice once at my school and once with my BenQ FP71G Monitor. At my school the monitor ( HP ) just stopped working and smelt like burnt popcorn.(though is think this is due to some kids chucking a soccer(football) ball at it! With my BenQ it has the same problem though i nownthink it is because of the monitor has been on for excessive hours ( 3-4 ) and just shut down because of overheating. I will see in a couple of hours if it works !
Copper_R
Dec 30, 2007 | BenQ FP71G 17" LCD Monitor
Benq monitor powers off immediately
Try sending monitor back as most Benq monitors come with at least a two years silver warranty. Benq are very helpful and their repairers are quick and polite. You will find their no.s on their website www.benq.com my monitor was experiencing the same and for $10 postage and a one week wait is repaired and working fine.
Apr 07, 2007 | BenQ FP71G 17" LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
2,201 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
