Question about Kitchen Ranges
Tappan gas stove model # 30-4942-00/02, serial # VF33800811 has been intermittenly displaying -F2- where the time is usually displayed. It also beeps when this F2 flashing begins. Help! what does it mean?
  • wujekartur Oct 22, 2008
    stove timer constantly counts down from 2hrs down
    keeps beeping
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Posted on Nov 07, 2007
  • 409 Answers
SOURCE: Gas Stove
sounds like the spark module is trying to relight the electrodes again. it could just be the electrodes. is it on all the elements?
Posted on Sep 13, 2008
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Posted on Sep 20, 2008
docjohn174
  • 943 Answers
SOURCE: I want to convert a tappan stove to lp gas.
hi thanks for the question the brass fitting at the burner unscrews to change from natural gas to lp if its screwed in all the way back that off till you get a nice blue flame do it to all burners thanks the appliance doc
Posted on Sep 25, 2008
shinn8
  • 85 Answers
SOURCE: What does F-1 mean on the electronic display of stove?
F1 is a failed thermistor control in the control board. Board must be replaced to fix. Part is in vicinity of $120.00
Posted on May 20, 2009
Hello, Can't find model/serial number. Older Tappan custom gas stove. Burners work but oven does not. Told it has electric ignition that could be problem. Where to find it, how to remove, where to get...
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Jan 30, 2009 | Tappan TGF363 Gas Kitchen Range
Oven controls
those failure codes usually mean the oven sensor is out of range or has an open circuit.
you can replace the sensor for about 50-75 bucks and that will allow the oven to heat properly again.
you wont need to do any reseting or clearing of the code, just fix the problem and that code will go away.
Jan 14, 2009 | Tappan TGF320 Gas Kitchen Range
Gas Stove
Sep 13, 2008 | Kitchen Ranges
Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
Hi Carlsr,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Apr 13, 2008 | Tappan TGF320 Gas Kitchen Range
Baking oven
if you got no display form clock assy ck the power lines leading to that control, unplug and relpug unit might have just glitched out, no clock no bake on this model all oven function run throughthis clock/control
Feb 28, 2008 | Tappan TGF363 Gas Kitchen Range
F1 and F2
TAPPAN
Code
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Oven won't start
Open the bottom storage area drawer, Look to the right for a badge with model / serial number.
If the over has the following options..
Self cleaning work ?
Broiler work ?
Oct 10, 2007 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
