Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w14 power off
Power light turns on and off three times, after a while of repeating this the tv will come on, is it a bulb or something else.
  • Anonymous Oct 17, 2008
    I was watching my 3 year old 52" big screen rca tv yesterday and it went off. I tried putting it back on the power light went on then i heard a pop and power light went out. I checked the tv and smelled smoke. Now all i have is a big tv that power light comes on then goes off.
  • mbasports Oct 19, 2008
    We have the same problem with the blinking. When the blinking ceased, a white fuzziness appears for a minute before the clear picture came on. Now it's dead. Blinks on and off three times, then...nothing.
  • 3 Answers
Same problem. It would TRY to come on 3 times, but nothing.
Mine was the Capacitor (cp150) that others talk about down in some of the other postings. I replaced the capacitor (man, what a pain it was taking apart all those plugs, etc) but that was the problem. I upgraded to a 35v 2200uF because radio shack didn't carry the 16v 2200uF.
It took me about 2 hours to complete this task of unscrewing the 20 screws (star-head screws, btw) on the back of the unit, unplugging about 10 connections inside, just to get the Printed Circuit Board (PCB) to twist out so that I could get to the capacitor and do the soldering. I suggest that if you use the radio shack replacement that you locate some type of insulation (black high quality electrical tape will do in a pinch) to put around the leads, because the capacitors look different than the one that you take out and the size is a little bigger and you have to leave the leads longer because it goes in sideways and you don't want them touching the metal [_] piece later on and shorting out.
I'm a novice at this fixing my own stuff game and this is only my second attempt and thus far, thanks to THIS WEBSITE, those who I have followed the advice of has worked. This was much more difficult than the monitor that I repaired 6 weeks ago. Saved me $250 for a new one.
Fortunately, on this model TV, all of the plugs/ribbons that you have to undo to get the PCB to twist out, all only have only one place that they will fit back together in.
The only reason for my post is to tell you that if a city cop with very little basic understanding of circuitry can do it, you might can as well. The capacitor costs $4.89 and it took me about 2 hours total from the time I turned the TV around to work on it, until the time I set it back around and turn it on. I've no idea what a TV Repairman charges per hour, but for two hours of work, it would've been a healthy fee + the markup on that capacitor.
I have no idea what a flyback is but it costs $60 at that website that they advertise in other postings. I tried the capacitor because: A) it was a cheaper fix, and B) I felt like my unit was getting power because the green light would come on in front. Good Luck! -Tim (30117)
Posted on Oct 22, 2008
I have the exact same T>V an mine done basicly the same thing only no smoke,
It Probably wasnt a good thing to plug it back in... you'll need a Flyback , Im trying to get the exact part number an a place to buy it, as well as a Manual How to do it my self... Ill post back when i get it... Cheers for now.
Brandon0515
Posted on Oct 21, 2008
2 Suggested Answers
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
RCA Proj TV (model D52W14) Power light flashes 3 times
Replace CP150, CP120 and CP114. You can get the repair kit for your RCA at the following link. www.tvrepairworld.com the kit contains the capacitors and the CD with detailed instructions.
Sep 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w14 power light comes on briefly then goes
1. the supply had a fault and needs to be repaired or replaced.
2. www.partstore.com might have your supply or you can pre order it from them.
Good luck hope this inforamtion does help when it doubt get a service guy to come out.
thanks and please rate.
Aug 22, 2009 | RCA HD52W58 52" TV
Rca d52w14 hit power green light blinks three times wont come on
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv d52w14
replace the flyback 25296 and the CP150 and CP114 capacitor. You can get the flyback and the capacitors at the following link and they provide free installation instructions with pics so you can easially do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | Televison & Video
Rca will not turn on
16v 2200uf capacitor on the 6v power supply bad top of capacitor usually domed
Aug 17, 2008 | RCA HD52W58 52" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
459 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
