Question about Medion MD-40954 Notebook
I loaded yahoo messenger 9...try to use it...says there is a problem
Yahhoo Messenger....deleted all yahoo icons..on laptop....re-installed all again....still messenger does not work...it is messenger 9
Yahoo messenger 9 not opening
download a latest copy yahoo messenger, sometime when your yahoo messenger become old it cant log you in download from here
Click here to Download
install yahoo messenger then log in again
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Apr 05, 2009 | Yahoo Messenger
If i double click the icon yahoo messenger will not come on or if i uninstall it will not do it
I suggest you download Ashampoo-UnInstaller from http://www.download.com/Ashampoo-UnInstaller/3000-2096_4-10032301.html
and try to uninstall yahoo by this software and then re-install your yahoo messenger, I hope it fix.
But if this software couldn't help you, I suggest you to delete yahoo messenger manually (goto C:\Program files) and delete Yahoo messenger folder manually and try to re-install your yahoo messenger.
Good luck
Feb 25, 2009 | Yahoo Messenger
I can't open Yahoo messenger
left click start go to ((control panel)) left click
control panel
((((num1))) if you have classic view left click programs and features left click to open>>>>left click yahoo to unistall
(((num2))) if you have the Control Panel Home under
program left click ((uninstall a program)) delete yahoo there
now go back to start left click ((( search )))
type in yahoo delete all yahoo files there
restart your pc
TRY INSTALLING MESSENGER VERSION 8.1 COMPATIBLE WITH VISTA HERES THE LINK HOPE IT HELPS.....http://messenger.yahoo.com/download/vist...
IF SO RATE ME PLZE...
Jan 20, 2009 | Yahoo YHT-630 System
I cant install yahoo messenger 9 it says not valid win32
Try deleting all your temporary files.
  1. Click Local Disk(C:)
  2. Click Documents and Settings, Your Document Name
  3. Local Settings
  4. Temp Folder
  5. Delete all the files inside the Temp Folder
Delete all your cache, internet temporary files,and cookies
  • Open your web browser
  • On the toolbar menu, Click Tools
  • Delete all files (History,cache,temp files,cookies).
Uninstall your previous YM installation. Reboot your computer. Download and reinstall your Yahoo Messenger.
Dec 26, 2008 | Yahoo Messenger
Yahoo Messenger 9 Vista Installation Problems
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Dec 09, 2008 | Yahoo Messenger
My yahoo messenger application is not responding
http://help.yahoo.com/l/us/yahoo/messeng...
i cant access yahoo live messanger. i deleted the icons by mistake
Oct 18, 2008 | Yahoo Messenger
Yahoo messenger 9 wlll not open
goto control anel add remove prog delete messenger and download again get from download.com better use DAP accellator for fast download you get free from www.download.com
Oct 13, 2008 | Yahoo Messenger
Yahoo Messenger 9
yahoo messenger 9.0 was not loading for me....so i tried to re-install it..tht ddnt work...thn i deleted all the files manually and removed the program... but now wen i install it it stops at 99%..i saw somewhr a suggestion...it helps to reach 100%but again the loading prob.. so in short nothing worked out.. i tried several times to install... it stops at 99%.... YAHOOOOOOOOO plzzz help. i use windows XP.
Oct 05, 2008 | Yahoo Messenger
Yahoo Messenger will not load
I have a desktop computer and downloaded ym 9.0 for vista it loaded but will not pull up when i click on it it freezes.
Sep 26, 2008 | Yahoo Messenger
Medion MD-40954 Notebook Logo
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
