Question about RCA 35V432T 35" TV
RCA: buttons and remote won't work
I have an RCA 35V432T 35" TV, about 10 months old. The power and other buttons on the front panel don't work (have verified that child lock isn't activated). The remote works but only within about five feet of the set. Just a few weeks ago everything was fine; remote worked from 15 feet. I've checked to ensure that no new electrical interference has been introduced (eg invisible dog fence) and no other electrical appliances are malfunctioning, so I don't suspect a lightening strike. I also bought another remote and found that it too works only up to five feet. Perplexed, so any insight will be helpful.
  • Ted Marx Jun 05, 2006
    Thx, not the batteries and sensor window's clean. Question now becomes whether labor (not covered by rca warranty, but parts still are) exceeds the value of the set.
  • Ted Marx Jul 30, 2006
    Dr. Dave:
    I'm no tech but this one ends in a funny way. I think this will help.
    It wasn't my wife, it was our baby son. Here's how I solved it. The tech approach etc. was more expensive than the set so I decided to destroy the thing as we couldn't lift it. Took the cover off (which was hard). Looked all over and didn't see anything obvious. Had hammer in hand, was ready to smash into smaller pieces. Then I noticed a little card with circuitry on it up by where the buttons are located. It was slightly out of place . . so that circuits weren't being activated by buttons and remote control sensor was tilted away from sensor. I adjusted the card, fitting it back into the slot. Then I filled a few buckets with water, stood back with the set plugged in, and hit the remote. I figured the thing would explode so I had the extension cord ready to yank to be followed by onslaught of water Alas it powered up. I hit the buttons one-by-one and they all worked. Put the cover back on and we're still using the tv today. Why the baby's fault. He liked to push the buttons and it seems he pushed them so hard that it knocked the card out of place!!! Remote worked only within inches because of the resulting tilted angle of the sensor.
    I hope this helps. More technically-oriented people here can probably give you better guidance on how to manage this repair. It wasn't easy and I'm surprised I got everything back in place without ruining something.
    Problem Solver:
  • 9 Answers
Iv'e got the same problem. I'm not sure what to do, I think im just going to get a new stereo. The CD player has gone bad to. That doesn't leave much of a stereo left.
Posted on Jun 19, 2009
I don't have the solution, but the same problem w/ my RCA,and the solutions seem to skirt the issue, the problem wasn't with the remote other than the op.range. The problem was the inop. front panel buttons, and I am also eagerly waiting for a solution that might help our issue! Thanks! no disrespect intended!--DrDave
Posted on Jul 30, 2006
    President:
  • 3,130 Answers
The fact that the front panel buttons dont wprk is an indication that theres a control problem. could be a low b+ going to the processor or something such as an leaky or stuck button. But your still gonna need a tech. Good Luck
Posted on Jun 04, 2006
  • 215 Answers
I assume you tried changing to known good batteries. It's been known for people to get what they think are fresh batteries but they are old ones left lying around. If you've changed remotes did you put your old batteries in it too? If you are using new batteries then there must be a fault with the receiver which is a tech job. Oh Yes, make sure the receiver's window is clean. Over zealous wives can leave cleaner spray in the window and that can cause problems. BMW
4 Suggested Answers
SOURCE:
  • 1694 Answers
SOURCE: power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Posted on Sep 26, 2007
techman
  • 3130 Answers
SOURCE: FPA Locked ON
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Posted on Jan 24, 2008
MARR
  • 49 Answers
SOURCE: My RCA F32650 won't turn on and green power light just blinks.
yeah the blinks will tell u the culprit..basically cold solder,or bad vertical ic.but u need prof tech to help u fix that..hope this help..yhanks
Posted on Feb 05, 2008
My RCA tv won't work without a remote, and I can't seem to reset since I don't have a menu button
Hello
If your TV has no menu button on its front panel, there is no other way than buying a universal or original remote control to this set.
Mar 04, 2012 | RCA Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My screen extends past the edge of my tv how to i adjust this
Find the Format or Aspect button on the remote and push it until you have the size you desire.
May 02, 2011 | RCA 35V432T 35" TV
I have a RCA 35V432T. The TV is not turning on, I can hear it clicking on and off only. Any ideas?
Hi - probably not worth fixing, I'm afraid. That set is a lower-end RCA with a common problem, the EEPROM chip needs to be replaced.
Feb 28, 2011 | RCA 35V432T 35" TV
Rca tv makes hi pitched whistle when plugged in.
You have a bad horizontal transistor and a possible bad flyback transformer! These two components are indicating a short in your horizontal deflection. Thanks for asking!
Jun 06, 2010 | RCA 35V432T 35" TV
RCA 35v432t won't turn on
have a technician check it ...might be a power supply gone bad
Aug 11, 2009 | RCA 35V432T 35" TV
Doesn't rcognize DVD players
You aren't trying to use channel 3 or 4 are you? That's for RF connections only.
There are probably AV input channels on the set that aren't accessible from the channel up/down buttons. On my set there is another button to switch between inputs and channel select.
Mar 23, 2008 | RCA 35V432T 35" TV
RCA 35V432T Dead Set
Check for a high voltage power supply section of your TV set...
Especially in flyback transformer.Be careful to do so because the output voltage of the flyback transformer is almost thousand volts.
Oct 17, 2007 | RCA 35V432T 35" TV
RCA 35V432T 35" TV Logo
3,050 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
