Question about Motorola Mobility RAZR V3i Cellular Phone
Screen goes white
Hey i have the same problem with a new razr i just got. the screen goes white although i can still answer calls and such. i f i turn my phone off and back on it works for a while until it does it again. what did you mean in your reply to the other person to reflash the phone to correct the problem. what is reflashing the phone and how do i do this?
    Brigadier General:
  • 7,752 Answers
Reaplced the lcd on the phone to correct this issue
Posted on Dec 28, 2008
Screen won't turn off. Goes white
Have you tried turning your phone off and removing the battery.
leave your phone off for like 15-20 mins.
then replace your battery and wait 15 seconds before you turn it back on it should help you.
May 29, 2009 | Motorola Mobility RAZR V3
My motorola razr v3 screen keeps going all white!?!
first, make sure your Razr has no physical or water damage. If it's a T-Mobile phone, there will be a red sticker on the phone behind the battery. That indicates the phone as been exposed to water damage. Could mean the phone is shorting out on you. Now, I would suggest if the is NOT water damaged, to powercycle (turn off and on the phone) daily. Just off for about 30 seconds. Not long at all. If the white screen continues, do a master reset. Settings, -intial set up-master reset-code is 1234 or if you put in a different security code.
This will work!
Jan 29, 2009 | Motorola Mobility RAZR V3c Cellular Phone
V3x problems
Try to update the firmware. you need to flash it using RSD lite software and you can download this for free on forums related to motorola and even firmware is available there.
Hope this info helps
Jul 21, 2008 | Motorola Mobility RAZR V3x Cellular Phone
V3x problem
take it to a store and see whats wrong if you sont want to check inside your phone and see if the sim card is broke or if theres a wire or something
thanx Elise
Jul 17, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Screen/Power issue
u must go to motorola service center to get it repaired they know the solution
May 19, 2008 | Motorola Mobility RAZR V3
My cell keeps shutting down when i try to turn it on
i have a razor vx3 that was doing this every time i would get a phone call. I returned it for a new phone thought att.
Dec 03, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Phone won't turn on
You may need a new battery. Also, hold the power button in for at least 10 seconds before letting go. The RAZR has a bad habit of not completely turning on unless you hold it in long enough.
Nov 30, 2007 | Motorola Mobility RAZR V3
Motorola Razr front screen blue, inside screen white/blank
this i did find a guide to opening the moto up .
http://themotoguide.com/razrdisassembly.php
hope this helps you out.
riz.
Nov 12, 2007 | Motorola Mobility RAZR V3c Cellular Phone
V3 razr goes to white screen
software problem u must contact service center and do flash it
Jun 15, 2007 | Motorola Mobility RAZR V3
Retarded razor
I don't know why you can't answer your phone or why you banged it to get it to work but your inside screens connector may just have came loose as it sometimes happens with out you doing anything wrong. Just take it apart and check the wires on the solved problems I think there one that tells you how to do this.
Mar 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
