Question about Abit NF-M2SV Socket AM2/ MCP61S/ DDR2-800/ A&V&L/ MATX Motherboard
Midi Driver I am trying to connect my Yamaha keyboard to the PC and record sound, I am running windows XP with Cakewalk Pro Software and connect to the yamaha keyboard to the PC via a USB cable. On my old PC when I had the same setup (older motherboard though) when you press a key on the Yamaha keyboard a symbol would flash red in the menu bottom right of the screen. Now although the symobol is there it just stays 'grey'. I checked Device Manager and was expecting to see a midi driver, bu there is not one listed, I am assuming that this is my problem. Can I get a new midi driver anywhere ? Thanks in anticipation
    Genius:
  • 1,066 Answers
Check the yamaha website for drivers.
Posted on Mar 11, 2009
I cant connect my yamaha ypt 320 to my pc using the midi
Assuming you have a MIDI interface on your computer, you need to connect the MIDI cables between the keyboard and the PC. You cross connect, that is, in to out and vice versa. You will ALSO need the driver software for the interface in the PC AND most importantly, some software in the PC to handle the MIDI for instance to record.
Mar 27, 2011 | Yamaha YPT320 61 Key Personal Keyboard
Hello, I have the MIDI kit and it is pluged in, how do I get the music to the keyboard or keyboard music to the computer? I want to recoard some music for singing, please help. Thank you, Princess
In Device Manager (I am assuming you are using Windows XP) you will find your MIDI devices under Sound, Video and Game controllers. It is possible that the MIDI port has not been enabled in BIOS, I have had some PCs where this had to be done first. If Fruity Loops doesn't give you any available MIDI port to use it does not sound as though the PC knows it's there or has installed the driver properly. Start in Device Manager - if there's no MIDI port there or it's not working for some reason you'll have to fix that first.
Mar 03, 2010 | Cakewalk Music Creator 4
How can i play BUP 06PK61 frm yamaha I425 on PC
how can i play .bup file in computer?
ok here is the solution!!!!!!!!
    • we should have a mic pin and audio cable as shown in this pic
    connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
    now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
    now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
Jan 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
I am trying to install yamaha usb-midi driver software on my laptop powered by windows vista. getting this error 25001 (no device connected message). help please
I know this sounds weird, but make sure you connect the MIDI-OUT cable to the MINI-IN port on the keyboard, and the MIDI-IN cable to the MIDI-OUT port. Backwards and illogical, but there it is.. I had the same problem; now it works flawlessly.
Dec 05, 2009 | Yamaha Audio Players & Recorders
How do i hook it up can it be used threw the usb or does it have to be connected with midi
As far as I can tell it will connect with USB as it has a USB connection.
Nov 17, 2009 | Edirol PCR-50 Keyboard
MY MIDI NOR SIGMA TEL HAS SOUND OUTPUT
Signma Tel is notoriously bad for recording. It often doesn't work. But try changing your driver mode and then running the wave profiler. restart everything and make sure that your sound card is chosen under playback timing master and recordi timing master so that it is the chosen card. UNLESS- the keyboard has it's own sound card or interface built in, then its a different thing. You'll have to find out what kind of drivers THAT card uses and do same thing choosing that as card with correct drivers. Also check MIDI devices and make sure its in there. U might wanna email tech cuz this is a little more complicated than a regular set up
Feb 17, 2009 | Cakewalk Music Creator 4
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Cakewalk software: Midi vs. Sound
You can get a music keyboard for around $200 and up.
http://www.zzounds.com/cat--2684
Or use it as is, with your computer keyboard. There should be a printable template on the disk, if not in the package.
Yamaha 61 key keyboard midi usb connected but what next
Depending on what you want to do...
If it's only music Mixing, you will have to plug your keyboard via audio jack to the line in of your computer. Then Audacity (free soft) can do the job.
If you want to edit midi file with your keybord you will need midi editor software like Linux-Rosegarden or if under windows try LMMS (all free soft of course).
Good luck
Oct 16, 2008 | Yamaha Portable Keyboard
Abit NF-M2SV Socket AM2/ MCP61S/ DDR2-800/ A&V&L/ MATX Motherboard Logo
477 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
