Question about Mitsubishi WT-46805 46" Rear Projection Television
Mitsubishi WT-46805 Problem with image on screen. While looking at tv the image is cast with a yellow look. When looking at the projector units from the backside, the blue one is not firing. Yet below the unit there is a glow that seems to be the same with all three units. What may cause this unit to be out, even though it intermittently comes on and works properly when on?
  • Mitsubishi Master
  • 8,617 Answers
Most probable cause is a cracked or bad solder joint on th blue CRT drive board which is the small board attached to the bottom of the blue CRT
Posted on Jan 08, 2009
I have a WT-46805 Mitsubishi rear projection tv. The screen was accidentally pushed in and now has a crease. It was also missing the protective glass in front of the screen. I also have a broken model...
Check following image taken from related service manual that shows how to take off front screen from WT-46805 tv.
Hope this info will help you.
Please click HERE to download service manual copy, if required. It has schematics, parts list, exploded views and all technical info of WT-46805 tv. (service manual is available for 2 days only)
Thanks.
Nov 13, 2010 | Mitsubishi WT-46805 46" Rear Projection...
Opening a mitsubishi wt-46805 HDTV
Pretty sure you just pull the front lower cover from the side edges.
And then there is a smaller cover with a few philips screws holding it (lower front) , to remove the upper section you then remove the screws just under the screen edge about 5-6 screws. unplug the two cables and slide the screen straight up and pull it out, hold it with one hand on the bottom and one on top so you don't drop the screen.
hope this helps you can get the actual service manual here for a few bucks
thanks
Eric
Sep 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Convegence sectors will not move
The convergence ic's need to be replace. This should be done by a repair shop.
Nov 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WT-46805 46 in. Rear Projection Television- No Picture
I had audio and no video. Now I cant get ant thing and the TV turns off by itself
Jul 28, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi big screen tv model no. wt-46805 year2000
Replace the convergence amp ICs. also shck the resistors coming out of the ICs
Jan 30, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Good Luck, big IRISH.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
