Sony Handycam DCR-TRV20 Mini DV Digital Camcorder
Problem for Sony Handycam DCR-TRV20 Mini DV Digital Camcorder
Rewinding the tape stops after a few seconds and eject comes on. Also battery dies in 5 minutes.
By Vinit on Jun 03, 2006
1. When rewinding a tape, after about 30 seconds, it shows an eject icon and starts making a pinging sound. At that point, you have to take out the tape, put it back in again and then again rewind.
2. The battery despite being fully charged still dies in less than 5 to 10 minutes of recording. (This could be related to the above problem since this has never happened before.)
Comments:
Jun 04, 2006
- I took the battery out and tried to rewind it and had the same problem. That (with your input) tells me that the belt/motors/stuff... need servicing/replacement.
Not sure if the battery dying in 5 minutes is related to the above problem or not.
What's a reasonable place to get this kind of work done in Dallas ? I called Wolf Camera and they charge 250$ to even take a look at it.
Best Solution
posted on Jun 05, 2006
Very Helpful)
ali sh
Rank: Apprentice
Rating: 95%, 2 votes
ali sh indicated that his solution for
VMH-675 Hi-8 Analog... Problem
is valid for all Sony Camcorders
i think this problem when emerge that the open/close sensor is dirty and you should clear with dry spray
Was this helpful?
Yes
No
Solution #2
posted on Mar 26, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had this exact same problem, I was stressed as i have sold the camera and was just testing to ensure it still worked. I took this advice and used the charger plugged in direct to AC (bypassed the battery) and the camera now works. I will try recharging and discharging the battery a few times slowly.
Thankyou so much for providing this advice.
Solution #3
posted on Jun 04, 2006
Helpful)
bmwrider
Rank: Wiz  Sony Expert
Rating: 84%, 1891 votes
It does sound as if your battery is giving up the ghost. How long have you had it? If it's an older type is it a NICAD. If it is perhaps it's built up a memory. Fully discharging and fully recharging 3 or 4 times can sometimes give it more life but if it's geting a bit old maybe a new one is in order.
Have you tried using the power supply and bypass the batteries altogether? See if the same fault occurs.
The halting rewind could be caused by a slipping clutch or slipping belt, Maybe it's time for a service. But tie the rewind problem to the battery going flat it sure sounds like a dying battery to me.
By the way, the charger light isn't saying the battery is good and fully charged, it's merely saying it can't charge the battery any more when the light changes color or goes out or whatever indicates a full charge.
BMW
Was this helpful?
Yes
No
Solution #4
Not Rated)
bhadwaachodh
Rank: Apprentice
Rating: 0%, 0 votes
I took it to Radio Shack (they charge a lot more reasonable amount to take a look at it).
Apparently some card needs replacement & it will cost me around 200 $ to fix it.
So I've mothballed it and bought another camera. :-(
Was this helpful?
Yes
No
Popular Solutions for Sony Handycam DCR-TRV20 Mini
Questions and Unsolved Problems for Sony Handycam DCR-TRV20 Mini
Do you recommend Sony Handycam DCR-TRV20 Mini DV Digital Camcorder?
Answer
Answer
I cannot load the tape in the Sony camcorder....when the device is empty the tape holder will... (More)
Answer
when I put the tape a beep sounds and it tells me to eject it
Answer
cassette warning icon flashes rapidly, when you open the camera the cassette does not auto open or... (More)
Answer
and also cuts of irratically blinking clicking confused could it be selecter switch is dirty so,it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Handycam DCR-TRV20 Mini...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
