Question about Dryers
GE dryer is getting louder when running
Runs really good, but now louder when running. Not a squeek of metal on metal. Looked under top and front seems fine (the teflon spacers and felt belt in front look good). Sound seems to be coming from back area of dryer. What's up and what do I do?
How do I access the back and what should I look for?
Can't find the manual, do you know web site to get free manual
GE Super Capacity / 8 cycle / Heavy Duty / Sensor Dry / Quiet by Design
M# DWSR485EA 1WW
  • 550 Answers
Most common cause is the failure, or wear of the rollers at the rear,
the drive belt places a lot of torque on the drum, and it has rollers to support this force, in addition to nylon guides as the front has
good roller
worn roller
most dryers access from the front, the front panel and door come off,
here are generic removal instructions
with dryer unplugged examine lower front panel.
If there are two screws at lower corners
  • remove screws
  • swing front panel up from bottom
  • unhook top clips
  • undo door switch wires
  • set panel and door aside
If there are no screws
  • remove llint screeen from top
  • remove 2 screws from under lint screen
  • with putty knife or other blunt blade
    push spring clips at front top corners
  • tilt top up
  • remove 1 screw each side 1/3 way from top of dryer
  • tilt front panel down
  • undoor door switch wires
  • set front panel aside
Common to both
  • reach under drum to belt tensioner, pull tensioner to end of spring travel
  • unhook belt from motor and tensioner
  • withdraw drum forward
  • examine rollers felts nylon guides
replace rollers in pairs if worn
replace nylon glides if worn
replace felts if worn, the back one may wear before the front one, if the dryer is the open drum type,
Posted on Oct 17, 2008
Have a G.E. DRYER PDVH515 . It squeeks, roughly on every rotation of drum. Not a consistant long noise.It's been going on for some time now so wondering if greater damaged may be done? Thankyou
The sound is most likely from the rear drum teflon bearing failing. It may also be the front teflon glides. Or both.
The problem is not going to get better and will gradually get worse. You won't do any real damage if you continue to use the dryer.
However, if the sound stops being a squeak, and sounds more like a grinding, metal to metal sound, stop using it and call the repairman.
Mar 10, 2013 | GE Profile Wizard DPSE592EAWW Electric...
I have a GE dryer (DCVH660EHOWW) that makes a squeeking sound when running (louder when the wet, and heavier, load of laundry is first put in). I'm assuming it is either bearings that hold the drum or a...
Check belt tension Pulley through inspection plate at back of
dryer.
Oil it if you can get to it.
please rate me if this was helpful
Thanks
Leo Ponder
imufo2@sbcglobal.net
Jul 31, 2010 | Dryers
I have GE profile Model DPSR473EW with loud squeak when drum turns ? I also need to learn how to access the drum etc...
I have experienced two problems with "loud squeeks" with the DPSR473EW. First, if you take the top off (open door, remove two screws under top door lip releasing the top), then.., remove two small screws (inside up high - one on each side) holding the front panel/door assembly on. Pull the front panel/door assy away from the main unit - can't seperate due to some wires near the blower. On the door/front panel assy..., you will see four "teflon slides" that fit into a plastic semi-circular assy (the drum rides on those four teflon slides). Most of the time, this is where the squeeks come from - I've seen them worn thru..., and the drum riding on the plastic (just order the teflon slides - qty 4 - WE1M333). If the plastic piece that the slides fit into is worn, replace it - WE2M26 (top bearing). This should do it. If the slides look OK (so the squeek hasn't been fixed), the other place for a squeek is...., the back bearing. This bearing is basically a male rotating plastic sleeve running in a metal female hole. I have seen those wear thru the plastic bushing..., causing lots of noise. To inspect that bearing, you will need to a) remove the belt (plenty of instructions on the internet), then b)remove the drum..., then..., you can inspect that back bearing (two pieces - one piece on the back of the drum, the female piece mounted on the heater shroud.. If you need to replace that bearing, or one half of it - you can order pn WE25M40 - it will have both pieces. Good Luck
Nov 15, 2009 | GE Profile DPSR473EW Dryer
Dryer squeaks when turned on, recently is getting louder and louder as drum is turning. Is it worth getting fixed, it's six years old
The squeek is probably the front 'bearing' which is generally made of felt.
Pop the top, pull off the front, remove the drum. Clean the felt or replace it.
A better alternative is to turn up the radio so you cant hear the squeek.
If you do go to this trouble, you may want to replace the belt while you have it apart.
Personally, id let it squeek. It may be annoying but on the ohter hand, you know when it is operating and when it is finished now.
Oct 21, 2009 | Dryers
Dryer squeeking while tumbling & leaves black smudge on clothes
it sounds like a drum support roller is going bad or the belt idler pulley. i think maytag has a kick panel on the bottom that can be removed. look inside with a flashlight and you may be able to see something. if not, you may have to take the drum out to get a really good look. make a note and study how the drive belt serpentines around the motor, pulley, and drum so you can get it back together.
Oct 20, 2009 | Maytag Dryers
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Sep 09, 2009 | GE Dryers
GE dryer is getting louder and louder - not a squeek just motor seems to be running louder
THERE ARE THREE POSSIBLILITY. THE BLOWER WHEEL IS LOOSE AND BANGING ON THE VENT. THE BEARING FOR THE TUMBLER IS BAD, MAKING A LOUD SCRAPING NOISE. ROLLER BEARING IS BAD. WORSE CASE, THE MOTOR IS GOING BAD. GOOD LUCK
BOYNISMO@YAHOO.COM
Jul 04, 2009 | GE Dryers
Squeeks loadly when running
The drum belt is slipping or a support wheel bearing is worn.  Spray some belt dressing on the belt or replace the belt.  Lubricate the wheel bearing or replace it.  It is also possible that the seal between the drum and the housing (at the back) is worn and the drum is rubbing metal-to-metal on the housing.
May 28, 2009 | GE Profile Harmony DPGT750EC Electric...
My dryer squeeks when running
Hi, I've had a similar problem (I think) on my MDG7400 dryer. There was a cyclical squeak, metal against metal. It turned out to be the screw that holds the drum paddle to the drum. It had worked itself loose and was scraping against the inside wall of the dryer. Remove the front door lift the top, and tighten 'er up. Hope that helps.
Nov 19, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Ge electric dryer
most likely source of sqeak fornt front glides or rear bearing, the front glides can be seen be removing the front panel, 4 plastic strips the tub rests on and spins across, they will look worn or even missing if thats the casse( they simply twist on) as far as the rear bearing ,,a.k.a. "top hat" , for it looks liek a top hat, the drum is simply pulled foward and out of rear post and the bearing can be reinstalled without even removeing the belt form the pulley
May 12, 2008 | Dryers
Dryers Logo
774 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
