Question about Dryers
My Maytag dryer Model DE308 is very noisy. sounds like something is catching or grinding. can I fix this?
  • Anonymous Apr 26, 2009
    I have a Maytag DE 308 Dryer. I've taken the front panel off. I want to put it back on but can't figure out haow the retainer clips go on.
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Does the noise continue for a few seconds after the dryer stops?
  • 550 Answers
Most common cause is the failure, or wear of the rollers at the rear,
the drive belt places a lot of torque on the drum, and it has rollers to support this force, in addition to nylon guides as the front has
good roller
worn roller
most dryers access from the front, the front panel and door come off,
here are generic removal instructions
with dryer unplugged examine lower front panel.
If there are two screws at lower corners
  • remove screws
  • swing front panel up from bottom
  • unhook top clips
  • undo door switch wires
  • set panel and door aside
If there are no screws
  • remove llint screeen from top
  • remove 2 screws from under lint screen
  • with putty knife or other blunt blade
    push spring clips at front top corners
  • tilt top up
  • remove 1 screw each side 1/3 way from top of dryer
  • tilt front panel down
  • undoor door switch wires
  • set front panel aside
Common to both types
  • reach under drum to belt tensioner, pull tensioner to end of spring travel
  • unhook belt from motor and tensioner
  • withdraw drum forward
  • examine rollers felts nylon guides
replace rollers in pairs if worn
replace nylon glides if worn
replace felts if worn, the back one may wear before the front one,
if the dryer is the open drum type,
Posted on Oct 17, 2008
I have the same grinding noise when i first turn my dryer on.. i removed the belt to the drum and i still had the problem when i turned the dryer on, for a very short period of time, which points to the motor..
Posted on Jul 27, 2010
  • a9198d May 27, 2011
    The noise developed again months later .. what i found out was the fan cage was cracked on the motor shaft, and moving iin a wobble or egg shape motion, hitting the edges of the fan enclosure. making a noise as it hit the edges ,, the sound also depended on rotation and if the dryer was just starting, as in cold, or it was greatly reduced after it was running with heat for awhile..the sound sounded like a tennis shoe was rotating in it when the dryer drum was empty and turned on to rotate.
Where do I buy belt for Maytag de308 dryer?
There are various different appliance parts suppliers that you can find online to purchase a belt for your dryer. A couple of them are Sears parts direct, repairclinic.com. You could also check locally to see if you have a repair parts place in your town.
Apr 30, 2015 | Maytag Dryers
Not heating, in days prior and now the dryer became noisy, as if drum was rubbing something
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 29, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer (MDE4000AYW) making a sorta grinding noise when the start button is pressed then the drive motor starts up & the grinding stops. It sounds like a starter or transmission problem but I...
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
May 04, 2011 | Maytag Neptune MDE6700A Electric Dryer
Maytag performa electric dyer makes dragging noise drum turns but acts like something catches and makes a dragging or scraping sound
assuming nothing is stuck around drum pull off the front and check the fan. If it is noisy for a few seconds after you stop the dryer then the fan may be stripped on motor shaft. while off you can check the front glides and the rear rollers
Nov 17, 2010 | Maytag Neptune MDE4000 Electric Dryer
My Maytag dryer (model # MDE4806AYW) makes a grinding sound all of the sudden. Sounds like the cylinder drum is scraping on something. The dryer is only a couple of years old. What do you think needs to be...
Could be your front glides on your drum housing. They are just Teflon pads that the front of the drum rides on. If they wear down you will get a metal on metal rubbing. The part number is 40116501. The other possibility could be your rear rollers going bad but they usually will make almost a squeak usually. They are what support the rear end of the drum.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Dryers
Maytag Neptune MLE200AZW stacker-dryer sounds like an aircraft
IT IS POSSIBLE FOR THE DRUM ROLLERS TO WEAR OUT TO THE POINT WHERE THE DRUM DROPS CAUSING A GAP THAT CATCHES CLOTHES. AS FAR AS GETTING TO THEM, ALL I CAN SAY IS START TUNNELING INTO THE MACHINE BY STARTING WITH THE SMALL PANEL UNDER THE CONTROLS THAT IS HELD IN BY TWO SCREWS. ONCE YOU GET THAT OFF, IT SHOULD BE OBVIOUS WHICH SCREWS COME OUT NEXT. THE CONTROL DOES HAVE TO BE REMOVED.
Jan 27, 2009 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
899 people viewed this question
Top Dryers Experts
