Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
Viking VUD141 dishwasher timer stuck
I have to move the timer manually to get it going. Replace with a new timer but the issue still remains. What could be the root cause of this, burnt wire, fuse, or others? Please help.
Thanks.
Steve
  • washwu Oct 17, 2008
    Problem solved. After removing the kickplate and lower panel, a burnt wire connector was located and fixed. Everything is back to normal after that. If you have the similar problem like me, check the wire before replacing the timer. It costs me about $120 for the timer. The good thing is that I replaced the timer and fixed the connector myself. Saved $$$ without calling the service technican.
    Steve
  • jpsauro Nov 20, 2008
    same issue, time not advancing. not sure how to remove the front panel to check for wires though
4 Suggested Answers
SOURCE: viking vud141 - timer does not end the cycle
you can try this number 305-418-0010 they have everythin for viking product and very cheap
Posted on Feb 05, 2008
GodBlessU
  • 3513 Answers
SOURCE: I am looking for a
Hi
Please check the bellow link for the manual …
http://kitchen.manualsonline.com/manuals/mfg/viking/viking_dishwasher_product_list.html
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
Posted on Aug 19, 2010
KevinWhite
  • 1902 Answers
SOURCE: Viking Dishwasher Vud141 circulation pump
Hello & Welcome to FixYa
If the water fills fine and completely, then it means that the circulation pump is bad however, as you have already checked the pump and that is working then test the float switch located inside the bottom front of the unit. Please get back to me if you have any other questions.
Kevin
Posted on Aug 24, 2011
THERE ARE NO CLOGS ANYWHERE IN THIS DISHWASHER VUD141-SS. EVERY AREA HAS BEEN CHECKED FOR POSSIBLE FOR CLOGS. DISHES ARE CLEAN AND THE WATER CYCLES FINE. HOWEVER WHEN THE TIMER REACHES THE CYCLE WHERE THE...
yes the drain pump should start at this point so I would suspect a faulty drain pump,But try a reset first push and hold power button until lights reset then try a cycle if this fails to fix problem then I would suspect the drain pump.adrian,,,,,
Feb 11, 2015 | Viking Dishwashers
Need Owners Manual to see Wiring Installation/Pump Burned Out/Motor possibly burned out
Asko built d/w which is now owned by sub zero wolf. Fyi . To get parts you could call mfr direct which is cost effective. Hope this helps
Jul 22, 2012 | Viking 24 in. Professional Series VUD141...
How do I find the door lock and a door seal (bottom of door) for my Viking VUD141 ?
Don't know about the lock, but the bottom seal for the VUD141 is part # PD100091 (just had mine replaced).
Mar 20, 2010 | Viking 24 in. Professional Series VUD141...
My Viking Professional VUD 141 DISHWASHER will not pump water through the spray arms
I have a viking VUD140 and there is no power cord. Can someone tell me where the power supply is suppose to go.
Dec 30, 2009 | Viking 24 in. Professional Series VUD141...
Pump will not stop pumping
It may be in "delime mode" check the manual.
If not the timer is likely at fault.
Dec 24, 2009 | Viking 24 in. Professional Series VUD141...
Viking Dishwasher Timer Dial not advancing
The timer has given it up.  The motor has probably stopped working or the gears are jammed.  You'll need to obtain and change the timer.  Generally, there are face mounted screws that may or may not be behind some covers.  Remove them to get to the panel that holds the timer.
Nov 20, 2008 | Viking 24 in. Professional Series VUD141...
Left Knob Settings
On our model VUD141, the knob has a mark and the cycles are printed on the front panel. It is labeled as follows (starting from straight up and going clockwise):
OFF - Heated Dry - No Heat Dry Sani Cycles 165 deg F - Power Heat Selection - No Heat Dry - Heated Dry
Jan 05, 2008 | Viking 24 in. Professional Series VUD141...
Viking vud141 - timer does not end the cycle
Dec 09, 2007 | Viking 24 in. Professional Series VUD141...
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
239 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
bandman1967
bandman1967
Level 1 Expert
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
