Question about Sylvania 6427TE 27" TV
Want to view all my tv channels
Having trouble trying to view channels 1-47 channels very snowey higher channnels come in clear dont have access to owners manual at this time it is in storage help thank you
  • rezaras Dec 30, 2007
    i have tried to re-program channels but it does not work
There is no channel for the outlet you plug in for the video and audio
Posted on Jul 06, 2007
  • 215 Answers
It sounds like a bad antenna but coming from a land of only 5 stations across the country it's hard to give an answer. BMW
Posted on Jun 04, 2006
SOURCE:
My humax won't;t record bbc channels. I have tried retuning the tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
Have a look online for a Variable Signal Attenuator. It's a device that can be added to a aerial signal cable just before it goes in to the tuner. The adjuster allows the signal level to be reduced. Watch the TV's signal quality and signal level displays if it has them. As signal level (power) reduces you'll actually see signal quality increase. If you go too far then quality will start to go down again. The optimum point is where quality is highest.
Oct 08, 2014 | Humax Televison & Video
Only getting higher channels on my tv
Replace the small signal board. You can get replacement boards from www.tvrepairworld.com
May 27, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
It is not picking up the channels , i have cable and no channnels are working at all,not even the local channels.when am changing the channel it starts at DTV then TV,then CADTV,and then CATV
Sounds like you may have a stuck button on the tv causing uncontrolled selection or the Main bd is bad. Try hooking up a different source such as a DVD player to the same input on the tv. If the tv works ok you might have a bad cable Box as well.
Jul 08, 2009 | Televison & Video
Reset code for channel access
What's the model on the TV? Can try to look for the manual online. Might be worth a shot to try a capacitive discharge (unplug power, try to turn tv on a couple of times while power is unplugged, plug back in and try again). That may reset it.
Can also try going in the menus and rescanning for channels.
Apr 06, 2009 | Philips Televison & Video
Can not remove parental block on TV - can not remove parental block on Symphonic TV
Notes (for TV RATING and MPAA RATING):
● You cannot access the setup menu when the
“PROTECTED PROGRAM by ...” message
appears. Move to an unblocked channel
before you hit [MENU].
● When you select a rating and set it to
[BLOCK], the higher ratings will be blocked
automatically. The lower ratings will be
available for viewing.
● When you set the lowest rating to [VIEW],
all other ratings will automatically be available
for viewing.
you have forgotten the code, unplug the power cord
for 10 seconds to restore the access code to
0000.
download the manual for more details:
Feb 18, 2009 | Symphonic ST427FF TV
Setup
You have to do a autoprogram or channel search in the menu of the TV.The name of this function is different on some tvs general though in the main menu look for something like setup,channel search scan for channels .if you get it right your TV will begin to automatically start flipping channels and it will find all available channnels
Nov 15, 2007 | Televison & Video
Suddenly, can't get all the tv channels!
Try resoldering where the tuner mounts. Rca has had some problems with solder connections
Oct 16, 2007 | RCA F36649 36" TV
Sylvania 6427TE 27" TV Logo
196 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
