Reinstallation software having problems installing 4 port usb device after moving computer
  • 728 Answers
Try repositioning your computer and checking to make sure that nothing is wrong with the ports.
Posted on Oct 22, 2008
I want to update my Garmin gps
Follow the below mentioned steps:
Download the Garmin WebUpdater software which is available via the link in the References section. Installing the WebUpdater software is only required once. Follow the instructions in the software installation screens to install the product.
Insert the USB cord into the Garmin device. Insert the USB end of the cord into a USB port on your computer.
Move the cursor to the Start menu of the computer and select Programs / Garmin / WebUpdater.
Follow the onscreen instructions for the Garmin WebUpdater and then wait until the program has installed the upgrades to your GPS device.
5
Close out the WebUpdater program and disconnect the USB cord from the computer and from the GPS.
Apr 17, 2011 | Garmin GPS
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Hp 3005X PAUSES BETWEEN PRINTING EACH PAGE. Data light is flashing and LED panel displays "processing"
Thank you for contacting FixYa for your printer inquiry.
We have had this problem before. If you install the driver from the hp site, the dot4 port is not installed properly. We had to clean all the dot4 entries out of the registry and install the printer from the cd.
Remove Dot 4 Port Steps:
  1. Click "Start" and then right-click "Computer." Click "Properties" on the pop-up menu.
  2. Click the "Device Manager" link on the left side of the new window.
  3. Double-click the "Ports" sub-heading in "Device Manger." Highlight a USB port that includes "DOT 4" as part of the device description. Right-click on the port devices name, and then click "Uninstall" on the pop-up menu.
  4. Uninstall other existing "DOT4" ports using the same method.
  5. Restart the computer and log in to Windows.
  6. Reinstall the driver software that came with your printer's CD.
The printer now functions properly in Windows.
USB problems are usually fixed by reinstalling the driver, just reboot the machine.
Better still hook the machine up to a LAN this is a network printer.
Hope this helps. Don't forget to rate this printer solution.
TF
Feb 28, 2011 | HP LaserJet P3005n Printer
I downloaded the software and it doesn't find my printer during the install. i've had this printer for a couple of years and it worked fine during these years. i've since moved and now when i plug the...
Try unplugging the usb chord, uninstalling the printer (in device manager), then reinstalling the drivers.
If this fails, you may have a problem with your USB ports on your computer. Try different ports.
Zahc
Jan 26, 2011 | HP Photosmart 3210 Printer
Problem with usb port don`t work
Step 1
Before you start working on the USB port, make sure that your device is not the problem. If the computer says that the there is a new USB device but that it cannot use it, typically there is a problem with the device's driver and not the USB port. If this is the case, your best option is to re-install or upgrade the device driver. Try inserting the device to another computer. If the device works, most likely the problem is with the computer and not your device.
Step 2
Try rebooting the machine. Rebooting a computer resets all of the software to the default state and will clean up many issues. The start up process also checks all of the devices on the computer and can sometimes fix a USB port. First shut down the machine. Connect the USB device up to the computer and start it. This reboot will sometimes fix a bad USB port.
Step 3
Try attaching the USB device on to another USB port on the same computer. If the device now works, the old USB port probably has a hardware or BIOS issue. Skip to step 5 to try to fix a bad USB port through the BIOS. Fixing a hardware problem on a USB port requires working on the motherboard which is typically more expensive just adding a new USB ports.
Step 4
Uninstall your computer's USB device bus manager. The device manager controls the USB access and sometimes gets corrupted. Fixing the USB device manager requires administrator rights on the machine. The best way to uninstall the device bus manager is to right click on your computer's icon and select properties. This will bring up the hardware settings for your machine. Click on the hardware tab and select the device manager. The device manager lists all of the devices on the computer. The next step is to open up the "Universal bus controller" option. Right click on all of the items under this option and uninstall them. Once all of the devices have been removed, restart the machine with the USB device connected. Upon reboot, windows re-installs the USB device manager. Most of the time, this will fix the USB port.
Step 5
The next thing to try is to check the BIOS. Restart the machine and enter the BIOS setup screen. You should check to make sure all of the USB ports are active. If they are, you should try resetting the BIOS settings to the defaults. The BIOS reset will sometimes fix USB port. But if it does not you will have to consider upgrading the BIOS. Upgrading a computer BIOS is very dependent on the motherboard manufacturer and you will have to visit your computer manufacturer's web site for detailed instructions.
Step 6
The last trick to try to fix a USB port is to repair your OS. Sometimes the USB drivers can get corrupted and break the USB ports. You can reinstall the system files onto the computer which should fix the USB port. Your data files should not be changed in this process, but it is a good idea to do a full backup of the computer ahead of time. In windows, an OS re-install is done by loading up the windows installation CD/DVD and selecting the repair windows installation. Just follow the steps and you often have a fixed USB port at the end of the process.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 12, 2010 | Dell OptiPlex 210L PC Desktop
Support file isrt.dll not installed during loading of wusb300n I unloaded device and reran. I get "Cannot install this hardware. There was a problem installing this hardware." I followed Microsofts...
That would be correct. If it is USB attached and not PCI (internet/ethernet card)
I would try updating drivers for the linksys and then reinstall the software and manually set configuration
Jun 30, 2009 | Linksys WUSB300N Wireless Adapter
USB UNKNOWN DEVICES
methinks you are getting vistalized at the bios level..check on that by doing a windows update..
Oct 23, 2008 | Computers & Internet
Hp photosmart C4280 installed once worked great unplugged and moved problems. uninstalled reinstalled maybe 15 times now nothing works installation complete yet device icon says cannot detect device
HP printers can be very touchy about the way they are installed.
1) Disconnected the printer
2) Uninstall the software
3) Restart your computer
4) DO NOT PLUG IN YOUR PRINTER
5) Install the driver and only connect the printer when the installation tells you to.
The other source of problem is where the printer is connected to the printer, if it is connected to a USB hub (especially an unpowered one) it may cause issues. Try connecting to one of the ports at the rear of your computer.
Check your cable, maybe try another one, it could have become damaged in the move.
Oct 11, 2008 | HP Office Equipment & Supplies
USB ports suddenly not functioning
hi, see if you have installed any new devices/hardware to see if its conflicting, often grafics cards conflict usb devices, also just check that in the setup(when you boot up)that the usb ports have not been disabled or usb keyboard support hasn't been enabled/disabled. good luck!!
Apr 01, 2008 | EliteGroup nForce3-A Motherboard
My sony VGN N220E does not detect external devices
Try reinstalling your usb ports.
1. goto desktop, right click on my computer and press manage.
2. goto the device manager, find the usb devices / ports.
3. Make sure you are useing a ps2 mouse / keyboard since if your mouse/keyboard is connected to usb they will stop working untill your pc is restarted and the devices are reinstalled.
4. Uninstall all usb devices.
5. after all usb devices are uninstalled reboot the pc.
If the problem is with your drivers ( your pc detects the mp3 player but no drivers found) Download the newest drivers for your product and operateing system from the vendors website.
Nov 30, 2007 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
