Question about Sharp AL-1641CS Laser Digital Copier
Broken lights This unit is a Sharp AL1641CS scanner,copier,printer. The two long skinny bulbs on the scanner caraige are cracked. They are mounted on a black plastic board and mount to the top of the carraiege. Is the unit replacable and can you supply a part # and /or supplier? Thanks Jay Roese
  • Sharp Expert
  • 1,326 Answers
Are they broken or just don't lite up? Did you try to resolder the connections on the PCB first?
Posted on Oct 18, 2008
Printer will not print.Screen show blinking L & 3. What does this means.
Check the that scanner lock is not on. This lock is used to hold the scanner in place when you move the machine
Feb 12, 2015 | Sharp Al1631cs Al1641cs Al1661cs Copier...
Tip
Sharp AL Series Copier L1 L-1 Error Code Cause and Solution
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier L3 L 3 code meaning and solution
Good Luck and thank you for using Fixya
on Mar 16, 2010 | Office Equipment & Supplies
Toner drops excessively out of sharp 1641 copier
there is a used toner collection unit on the front of the toner cartridge if this fills up you must empty it or install a new toner cart. this unit will back up in to the drum unit causing issues also. if this happens you will more than likely have to take it to a tech to be cleand or replaced.
Jul 28, 2014 | Sharp Al1631cs Al1641cs Al1661cs Copier...
Need driver for sharp al1641cs for ubuntu
Sharp has the print drivers located on their website.
Visit sharp.com and you will have to follow some searches, but in the first search box on the site type in your model number and it will direct you in a few clicks to the driver you need.
Mar 31, 2010 | Sharp AL 1631 Copier
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
on Jan 04, 2010 | Office Equipment & Supplies
MY SHARP AL1551CS COPIER WILL NOT COPY OR PRINT AND HAS A L FLASHING ON THE SCREEN
The copier have a problem with the Scanner unit, see when you will turn off and then on the machine do the scanner lamp is lighting or not and also see do the lam is move from one side to other if the lamp is not lighting and do not move at all then you will need to see if is not move then something is wrong with the scanner drive or if is not lighting then the lamp is broken
Jan 28, 2010 | Office Equipment & Supplies
Copies now coming out with dark background sharp ar-m 207
Hai vipepheag
Please clean the scanner refflecting glasses,scanner lens,Scan bulb and Laser scaner units
One refflector glass is located at the bottom of scan bulb,another refflector glass is in left side of bottom and top of scan bulb
LSU is located inside and near the Drum units open side it include2/3 refflectors and one lens plean clean it all after problom continued check and condact me kabeercb@yahoo.com now and future
Apr 17, 2009 | Sharp Office Equipment & Supplies
Sharp AL1641CS
Its a heat roller error. Its reporting low temperature at power up. It needs a fuser unit or a new thermistor. Usually the whole thing is one assembly.
Jun 11, 2008 | Sharp AL-1641CS Laser Digital Copier
No Copies
It could possibly be your main charge assembly. If there is no charge on your drum, it can lead to blank copies.
May 20, 2008 | Sharp AL-1641CS All-In-One Laser Printer
Sharp AL-1641CS Laser Digital Copier Logo
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
