Question about Panasonic KX-TCD580 Cordless Phone (KXTCD580EM)
Phone fault We went away for a week and when we got back, the phone does not work! It rings when a call comes in. It lights up. But pressing any keys has absolutely no effect.
I have a small problem with my hands free set.What should i do to repair it. My e-mail address is lloydbangura@yahoo.com
Posted on Feb 05, 2008
  • 64 Answers
This is a known problem, probably a keypad circuits malfunction. try opening the device and clean the circuits with some anti static fluid. good Luck
Posted on Jun 06, 2006
Why can't I answer a call on line 2?
Confirm the extension # you are working with and that the line 2 key is line 2. do this by pressing feature *0 and the pressing the intercom key, observe the display and then press line 2 key and view display. then go back in the programming and view line 2 apear&ring, change it until it is apear&ring, then release and check for working again. If this dont work check to see if line 2 is programmed as a private line.
Jun 17, 2015 | NorStar T7316E Corded Phone
Loud squeak coming from back right suspension, went to shop and got it sorted, now noise is on back left side, what is it?
i bought lancer 2005 last week the srs light was on it needs a ring in behind the stearing wheel but how an ever its not causing any problems. i went to the shop today and the engine manegment light came on any idea s wat its for im in work i hav dignostic machine at home was jus wonderin is there any common faults with the lancer ? its 1300 cc
Jun 19, 2011 | 2005 Mitsubishi Lancer
I work for the Western Regional Day Report Center in Huntington, WV and we are using one of you Panasonic KX-TG4500 phones and Line 1 will light up when a call comes in, but WILL NOT RING. Now lines...
Check to see if the ringing volume is turned down,
On the base unit press the menu button and scroll to ringer settings using the up and down arrow keys, press the enter key.
Scroll down to ring group and press enter.
Press the left or right arrow keys to select the line desired.
press the down arrow key to move to Ext #.
Enter in the disired extension number starting with the base as Ext 0.
press enter to save.
Apr 05, 2010 | Panasonic KX-TG4500 Phone
I work for a small non-profit organization and we have a Lucent phone system - the problem is that when ANY call comes in on the mail line - it rings on everyone's phone. How can I fix this so that it...
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming2_bing.gif.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Dec 18, 2009 | Lucent PARTNER18 Corded Phone
The phones worked great for about a week and then they stopped working altogether. There isn't a dial tone but the phone does ring when there is a call. We press talk and nothing happens.What went wrong...
it sounds to me like you just got a hold of some faulty units. if you have the reciept i subjest you return them or have the store you bought them from replace them. your units should work longer than a week.
the problem your speaking of is a manafacture fault.
return or have them replaced.
Nov 12, 2009 | Panasonic KX-TG1033S Cordless Phone
Ringer rings on other desk now, not mine. LIght
Trying pressing that light and 1 key. Sounds like a night transfer key is on. This will work if you have a CTX system.
Nov 06, 2009 | Toshiba EKT 6010 S Corded Phone
Display screen on Nortel Vista 350 does not work It was working yesterday. It is not the line or the power supply I switched them It may be as simple as the equivalent of a burned out light bulb ?
Check the power adapter with a volt meter. The adapter is rated at 16 volts AC - mine puts out close to 18 volts AC.
Mine did the same thing - the right part of the phone (with the 350 on it) slides into the base - it must have come loose. I slid the part with the LCD display to the right, then back to the left (plugging it back in), and it worked (lcd and lights came back on).
If this doesn't work, and the AC Adapter checks OK, then you probably have a capacitor on the circuit board inside the phone that went bad. Unless you can replace electronic components (or are willing to send it away to be repaired), the phone will not ring, but you may still be able to answer it by hearing the other phones ring.
Jun 19, 2009 | Lands Phones
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Samsung d900i
what they should do is give you a new mobile or reflash the mobile for you
Mar 30, 2008 | Samsung SGH-D900 Cellular Phone
Panasonic KX-TCD580 Cordless Phone (KXTCD580EM) Logo
134 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
