Question about Logitech Z-2300 Computer Speakers
No sound from speakers
Hey, I'm sure this issue has come up but i couldnt find it anywhere. I've had my speakers and sub for about a year and suddenly the sound from the two speakers have cut out completely. The sub is still working, but the two speakers are not. Any suggestions?
  • Anonymous Mar 05, 2009
    Having the same problem here. The right speaker will *SOMETIMES* work but otherwise.. they seem to be broken. I contacted logitech about this twice. still no reply.
  • BJSievers May 23, 2009
    I'm having a similar issue. No matter the input to it, there's no sound
    from the speakers, only the sub. By chance I found out that if I press
    lightly on the speaker itself (with the cover removed) I can hear from
    them. Aside from this, no sound at all, not just quiet. Is it possible
    the speakers got blown? I've only ever seen the black film tear when
    that happened, not both speakers becoming perfectly disconnected at the
    center.
    New Friend:
FIRST CHECK WHETHER THE SPEAKERS ARE PLUGGED IN AND CONNECTED TO THE COMPUTER
Posted on Mar 19, 2013
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 164 Answers
Check to see if your computer settings arnt muting your speakers
Check to see to if the audio driver software isn't muting the speakers as well
Posted on Oct 22, 2008
JL Audio Amp. My amp all of the sudden started cutting in and out. It's an older amp and I've never had issues with it before. I've checked all the wiring and the fuse it all seems fine. Any...
you need to determine what impedance the amp is running at ,how many spekers ,most 2 channel amps will only run 2 4 ohm subs per channel and only 1 4 ohm speaker in bridge ,Basically if you have 2 4 ohm speakers bridged at the amp it will usually cut in and out .Some amps will not do this for a while and will work for a while at low impedance but once they get older and hot and cool off many times they will then only work for the intended ohm load ,Do you have 2 speakers ,if so make sure 1 is on left channel and 1 is on 2nd channel (should not cut off ) if it is a mono amp ,make sure you are only running 2 4 ohm subs and not dvc speakers (these will run 1 ohm and shut the amp down ) there are ways of wiring more speakers or dvc speakers ,I can explain but I need to know what product you have .
May 07, 2012 | Car Audio & Video
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
My Logitech Z523 Speakers make a loud humming noise when plugged into my PC. When i plug it into my phone or laptop there is no humming noise. Sometimes there is a fuzzy crackling sound when it is not...
Mine did the same thing then I found the solution by accident. After reading a post about moving the sub to different positions and making sure connections were tight to the sub , I loosened the right speaker connection screws to the sub and noticed the humming stopped completely . I know it sounds crazy but it worked for me.
Nov 30, 2010 | Logitech Z523 2 Speakers
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
Hey i had 2 car amps +for 4 speakers(140W maxi) and a sub 12inch
1 cap, either .5, 1 or 1.5 farad will be fine. they make 5 10 and 20 farad that cost way more than u need to spend for 400 watts RMS. i like the rockford fosgates, you can get a low cost Tsunami, just make sure you follow the charging instructions.
Oct 20, 2009 | Car Audio & Video
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
No sound coming out of z-5500
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 24, 2008 | Logitech Z-5500 Computer Speakers
Amp Issues
1) Make sure a bridged load of no less than 4 ohms is applied.
2) make sure both the left & right channels are working.
Jan 29, 2008 | Rockford Fosgate Punch P2002 Car Audio...
Subs
First of all you need to check if your amp can support this type of speaker setup? If you are simply going to wire 2 subs up to the amp (assuming a 2 channel amp) it's pretty simple. Just connect the + & - cables to one channel of the amp & the other ends of the cable to the sub, making sure that they are the correct polarity on both sides (ie speaker & on the amp).
If on the other hand you want to 'daisy chain' the subs onto one channel of the amp (this effectively drops the load down to half that of the speakers (usually 2 Ohm)), then you do as the name suggests. Simple connect one speaker cable to the amps channel 1 + ve output to subs_1 +ve input. Then from sub_1 -ve connector to subs_2 +ve. This leaves you with only 1 more to connect sub_2 -ve back to amp channel 1 -ve.
NOTE: make sure that your amp can support this first! If it can't then it's will auto switch off in most cases but can also damage the amp if there is no fail safe circuit built in.
Dec 24, 2007 | Rockford Fosgate FNQ1404 Car Speaker
Logitech Z-2300 Computer Speakers Logo
293 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
