Question about Kenmore 62872 Electric Dryer
Kenmore 90 plus series dryer won't work
First off, let me say that I have no idea if my dryer is the one indicated - I just had to choose something to get this posted. Its a Kenmore 90 plus series electric dryer. Push button to start on the right.
Threw a load in the dryer and heard loud screaching noises - sounded like a belt or something. It kept drying clothes, so I kept it going. As the cycle went on, the sound lessened and stopped.
I did about 4 loads with the same scenario.
Then, I put in a 5th load and there was a loud screach/pop upon pushing the start button - but it worked - in the same manner as above. I think it may have stopped in the middle of the load though, (not sure) cause the blanket in there was still damp when I tried to restart the dryer. Upon attempting to restart the dryer I got the following results: when I pushed the start button, no sound, and no movement/drying - dead.
Anyone have any suggestions of what I might try to fix this?
    President:
  • 2,992 Answers
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Posted on Nov 26, 2008
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 30, 2011 | Kenmore Dryers
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
I HAVE A KENMORE 90 PLUS SERIES DRYER. IT DOES
check the door switch and also check the belt,if the belt breaks there is a switch inside that turns the dryer off
Mar 19, 2010 | Kenmore Dryers
How to light the pilot for gas dryer, 90 plus series
Dryers haven't used pilot lights in over 30 years. You have an electronic igniter
Jan 16, 2018 | Kenmore 74602 Gas Dryer
Kenmore 90 plus series spin dry is not working
In resposnse to guest Dec 29th - I read further and later tested the lid switch. That did the trick. Thank you for the information contained on this site: not only did it save me a service call, but my wife was ready to purchase a new unit. Thanks to all those that have contributed in the past, your knowledge is invaluable to the do it yourselfer. C.F.
Aug 09, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore 90 Plus Series Electric Dryer trip
It sounds like the motor switch which is actually inside the motor on the model. It is very expensive to replace motor so it may not be worth fixing......
Although I stick to the above statement; I have seen cases where a thermal fuse wire has come loose and perhaps sometimes touching(allowing heat) and sometimes not(hitting something blowing the breaker.... Check all wires on blower vent area... GOODLUCK!!!
Dec 17, 2007 | Dryers
Kenmore 62872 Electric Dryer Logo
216 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
