Question about X2Gen MG19MY 19" LCD Monitor
Screen black My moniter was working fine, when I came back to it the screen was entirely black. I turned computer off and on and could hear the computer coming on but moniter screen still black
  • 4 more comments
  • luick Oct 20, 2008
    I have since changed moniters but tried once again to plug my X2gen in to see if it would work, now I get "no cable signal" unplugged the X2, plugged the other one back in and the signal is fine. This moniter is only 15 months old and I am very diappointed in it. Is there anything I can do. How long are the warranty's for?? Thanks, Luick
  • idosellphone Nov 02, 2008
    My screen just went black. It got dim, then black. When I turn it on again it would flash a screen then go black again. Disconnected it, shut power off and when I turn it on the power light just blinks. Grrrrrrrrr. I have had it for 21 months.
  • lcdfixneeder Nov 27, 2008
    screen started to "fade" and I clicked auto adjust and it just went completely black. The power light blinks on and off, and I can physically hear a click every time it blinks. Not sure if that's normal or not. I opened up the monitor to check for anything that looked bad, like the capacitor, but nothing looks bulged. could it be the power supply itself? I was thinking that might be it, but why would I get even a green blinking light if it was the power supply.
  • Anonymous Jan 12, 2009
    i have a 22in x2gen monitor and the screen comes on for like 3 min and turns black the power light is still on and if i power it off then on the screen comes on for like 3 or 4 min then goes black ? what do I do Please help Me?
    Regards
    Brucejenk@gmail.com
  • Fran Bednar
    Fran Bednar May 11, 2010
    Most warranties are only a year. You would have to check where you bought it to find out.
  • Fran Bednar
    What does the power button show color wise withit is plugged in and on (when the computer is on and when it is off )?
  • 348 Answers
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Posted on Oct 29, 2008
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
I have a samsung Syncmaster 2343 and I can turn it on just fine and my computer recognizes that it's hooked to a moniter but the moniter shows the screen for a few seconds and then it all goes black. It's...
If your up to opening the monitor it would do you well to look. It sounds close to what I experienced.Refer to Problems with Samsung SyncMaster 2053bw for info on opening.
Nov 11, 2009 | Computers & Internet
White static flickering on Viewsonic VA1912wb
Please check the line voltage 220V AC and check the earthing voltage 3V AC..
Jul 09, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Screen black
if monitor light is on, check the connecting data cable if it is ok then consult a technician.
Oct 28, 2008 | Computers & Internet
Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
My Acer LCD AL1711 went off after seconds of turning on.
This monitor has "back lights" that are essentially like flourescent lights. These are high voltage lights and can easily fail. since you are getting some light initially, I would suspect a defective part that heats up a bit right away and then fails. I would try to replace the entire backlight board. This is the small board on the side (usually).
Dan
Mar 27, 2008 | Acer AL1711BM (Black) 17" LCD Monitor
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Screen on moniter is not full
I think that you need to reinstall or find a new driver for it.
Sep 02, 2006 | E-Machines eMachines Monitor E15T4
X2Gen MG19MY 19" LCD Monitor Logo
199 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
