Question about Toshiba DKT-2010H Corded Phone
Toshiba RPCI DI Station Ringer
I have a Toshiba phone system, and we need to change which station rings when an incoming call comes in, I know there are codes that you can punch in that can control these feature, but I cant remeber how to do it and we apparently lost the manual. Can you help?!?!?
Which system?
The most popular is the DK system but it came in several revisions.
The primary differences are the way the ports are numbered and several program numbers.
Programming is done from port 005(ext 205).
The sequence of events is:
enter programming mode by pressing "speaker *#*#1*2*3"
enter ringing program
Day ring is "spkr 81 hold"
enter port number of the port you want to ring (example : 007#)
press buttons corresponding to the lines you want to ring then press hold.
To exit programming press"spkr ## hold then spkr ## hold.
Posted on Oct 24, 2008
No and we have two phones and neither of them can hear the incoming call yet they can hear us. Nothing happened to the phones they were working and then they did not.
Not likely defective, just need to be reset. If I understand correctly, no ring with an incoming phone call, but the intercom feature works fine. The ringer on the handsets is either "off" it will say no ringer or the base station is not communicating correctly. Intercom is handset to handset. Phone calls pass through the base station first. Of course, check the base unit: power on, phone line plugged in, antenna attached. Then try the phone line to check for dial tone with a regular, "old" analog telephone. If you are using these with a PBX, you must have an analog line installed.
Jul 05, 2014 | EnGenius DuraFon 1X-HC Long Range...
No ring for incoming calls on sprint 4g phone
I THINK THE RINGER OF YOUR PHONE IS NOT WORKING IT IS A HARDWARE ISSUE . GO TO THE SERVICE STATION. Krishna SKY LINK :-)
Feb 17, 2014 | HTC EVO 4G Sprint - /
I would like to turn off the ringer on this phone for incoming calls.
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Aug 20, 2010 | Avaya Corded Phone avaparp18d
I want another station to ring in addition to the operator's. It will ring at one station, but I would rather have it ring at another. It was ringing at the station I want, but doesn't now. I did move the...
Moving the phones shouldnt have affected the ringing. Phones are programmed on the ports which usually doesnt follow the phones if moving them. You will how ever have to program the ringing again on your system. To do this you will need the model number of your system StrataVI6e, DKT 40, DKT424,CTX, ETC... I have a site below with manuals on all Toshiba systems. However if you do know your system you can message me back and i will setup the steps to program your particular system.
Feb 25, 2010 | Toshiba EKT 6010 S Corded Phone
Turn off Ringer For External Calls Only
If you use strata emanager it would depend on how your system was set up. One way is to go to Advanced configuration tab Station tab, multiple call group tab, click on the group number (far right), then member tab and select extention and ringing option. Another way is to go again from the advance configuration tab, then assignment tab select the extention number on the right select key assignment tab, and on the incoming extention line double click it nd select no ring.
Jun 11, 2009 | Toshiba DKT3020SD Corded Phone
Choosing which lines ring.
If you have a multi line setup, you have a phone router. Have your phone company come in and program it for you.
Feb 17, 2009 | Toshiba DKT-2020 Corded Phone
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Ringer settings on 8825 base unit
You can adjust the volume and pitch of the ringing by pushing Menu, scroll forward to Desk Station Settings, push Select, scroll to Ringer Volume and you can adjust the ringer volume, and in that same area adjust the pitch. So you might want to make line 2 ring lower, and with a different pitch so it is not distracting, but still notifies you of an incoming call that is not line 1. The same goes for the handset.
Apr 18, 2008 | Siemens Gigaset 8825 Cordless Phone
We have no designated 200 STATION
Usually the operator's extension is the programming extension. Ext 200 is the default operator's extension.
You dial 200 and it rings a phone line not an individual phone? Do you know what your extension numbers are? (Some people never use them and do not know) If you do know some or all of your extensions, what is the lowest extension number?
For me to get you specific information, it would help to know which Toshiba phone system you have. (Not a phone) The systems all program differently. Did you obtain the manual recently and are you sure it is the correct manual for your specific Toshiba system? Again, the system is not a phone and your phone's model number does not narrow it down. All the Toshiba phone systems have a name and number on the front cover. Example: "Toshiba Strata DK 280"
Nov 12, 2007 | Toshiba DKT-2020-SD telephone
Blinking light but no ring sound on incoming calls
This is a phone system phone and each station you want to ring when a certain phone line rings has to be programmed into the system. This is not something you can change at the phone itself. You will either need to pay a company to make programming changes or locate a programming and installation manual for your phone system (not the phone) and try to re-program it yourself. If you have not done this before it will not be easy but it may be worth the effort so you can continue to make your own changes instead of paying someone $200 per hour to do it for you.
There is also the remote possibility your phone's ringer is broken. You can try swapping your phone with another of the same type and model to see if it will ring.
Oct 17, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Toshiba DKT-2010H Corded Phone Logo
249 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
