Question about Zenith H25F36DT 25" TV
Zenith 25" table top TV sentry 2
I have a red hue around a kinda fuzzy maybe darker than it shoud be is there a board you can replace I tried the menue sharpness and tint adjustments
  • 215 Answers
Many TV repair shops have what's called a tube rejuvinator. The modern versions can perform amazing changes to TV tubes. Many other techs treat them like snake oil but believe me I've seen the results of these machines and it makes one wonder why everyone doesn't use them. The new ones are logic controlled whilst the old fashioned or home made models aren't and can cause the tube to die completely. I've had a large TV not showing a picture unless all the lights were turned off and even then it was dim. 20 minutes later the TV was operating as it should. Two years later the same customer saw me in the main street and said the TV was still going like new. It doesn't work on every tube but I never had a failure with the unit I had. Mind you it cost $1200.00 but it made it's money back a few times. It's worth finding a tech who has one. It can be done in the home with no mess and only involves the back of the set and the neck board being removed. All up 30 to 40 minutes work. BMW
Posted on Jun 04, 2006
    President:
  • 3,130 Answers
Sorry to be the bearer of bad news bud, but thats the beginning of the end for your picture tube. The tube is what the industry calls a soft picture tube. On a set like this it wouldnt be feasable to replace unless you get a good deal and or you realy like the set.
SOURCE:
Need to try to repair old tv
Please contact any experienced service tecninican. Gopakumar Gopalan Google
Mar 03, 2014 | Televison & Video
I have a zenith plasma tv 50pc3db-ue flatscreen tv and when I hit the power button it goes green then back to red. I believe it is the relay switch. Can someone tell me what pannel the relay switch is on...
Power supply is the big board at the top middle, but a short on any board could do what you are describing, You need a Digital volt meter to trobleshoot further, look for popped or bulged capacitors or shorted components before purchasing more boards. Also look at Y-sus, Y Drivers (big board on the left 2 skinny boards.
Feb 17, 2014 | Zenith Z50P3 50 in. Plasma TV
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
Zenith sentry 2
picture horizontal in the tv
Oct 12, 2008 | Zenith H25F36DT 25" TV
Zenith sentry 2 television
All universal remote controls do not contain all possible codes. You may have to try a different one.
Dec 30, 2017 | Zenith Televison & Video
Blurry Image and Red Sparklies
maybe they messed it up and thought they fixed it
Jan 20, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Poor picture quality in new Akai plasma TV
This might be caused by bad interconnections maybe try using a different cable i hope your not using analog.I was told that the red dots are usually caused by interconnects such as analog.
Sep 16, 2007 | Akai PDP-42TD1 42 in. EDTV-Ready Plasma...
Zenith H25F36DT 25" TV Logo
789 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
