Question about Cameras
I have a Samsung L100. Its only a couple of months old and its never been dropped or damaged. When I turn it on, the power button turns blue, the lens opens, then it beeps two or three times and the shuts down - except that the blue light stays on. You can't use it and it you can't turn it off all the way without pulling the battery out. The screen doesn't light up or anything. The camera is totally useless now. I've found a few reviews online that say theirs do the same thing. Is there anyway to fix it?
SOURCE: samsung L730 won't come on...
how about give us our money back!
Posted on Jan 09, 2009
SOURCE: Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Posted on Jun 03, 2009
  • 3 Answers
SOURCE: three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Posted on Aug 21, 2009
  • 3 Answers
SOURCE: Samsung L100 digital camera beep problem
If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work.
If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
Hope this advice helps!
  • 11967 Answers
SOURCE: turn camera on, lens goes in and out then camera shuts off
Is it possible that at one time, the camera automatically powered off to save the battery. In this state, the press of any button starts it back up again. If while in this state, you put the camera in a case and the lens tried to open, the force may have caused your problem.
Posted on Aug 28, 2009
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Samsung digital camera L100 won't turn on.It's fully charged and blue light surrounding power button stays lit constantly.Purchaced May 2009
    Sounds like the software/firmware needs to be updated. Samsung will do it for $50 or you may be lucky enough to get a download off the web.
    Oct 23, 2009 | Samsung L100 Digital Camera
    Aug 04, 2009 | Samsung L100 Digital Camera
    Today, I was using it. Turned it off for a whle, went to ues it again & it wouldnt turn on, the power light was on & three beeps came out of my camera! It wont turn off until I take the battery...
    Most probably the lens problem, it got stuck or it's damaged. Try to gently pull out the lens to see is it only got stuck or take it to service
    Jun 23, 2009 | Samsung L100 Digital Camera
    Samsung L100 wont turn on
    Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
    Mar 30, 2009 | Samsung L100 Digital Camera
    Card error on L100 samsung camera, help please.
    copy all the pictures/files saved in your memory card to your PC then format the card, you can format the card by going to MENU > SET UP > FORMAT
    make sure that you have a copy of the files in the memory card because formatting the memory card will erase all the files that are saved in it.
    Mar 04, 2009 | Samsung L100 Digital Camera
    I have a samsung L100 digital camera. the battery had to be recharged but the lens cover only partially closed at the time that it shut down. I tried to recharge the battery, when I turn on the power...
    The battery was tested and showed to be fine. The camera just malfunctioned during the shutdown. The used battery was put into a new camera and it's been fine.
    Dec 25, 2008 | Samsung L100 Digital Camera
    It was the L100 and I'm sending it out for repair. Warranty is still valid. Thank you.
    Sep 04, 2008 | Samsung Digimax L730 Digital Camera
    Toshiba DLP 50HM66
    The bulbs for this TV seem to go about every couple years. The price has dropped down a bit. I have found it for 118.00.
    Feb 17, 2008 | Toshiba 50HM66 52" Television
    Cameras Logo
    78 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
