Question about RCA R52WH73 Projection Television
RCA 52 inch
Model number R52WH74 i was watching tv and it made a pop in the back of the RCA and it went black no sound and wont turn back on.
  • 1 more comment
  • bigbadd Nov 11, 2008
    i have a rca 52" projection tv when it quit it made a hissing noise now when you turn it on it will light the power button then turn off it does this three times
  • anchor57 Nov 12, 2008
    Thanks everyone u right it is high voltage right in front of the TV.
  • mecher50 May 11, 2009
    r52wh74 model itc222a chassis Makes a squeaky hiss right after power up.
  • 185 Answers
Three strikes and it's out... rca does this, it is just showing it has tried 3 times for you and untill it is unplugged it won't try again.. you need to provide model #.. could be a few different things
hissing usually meens you have high voltage...that's good but then what don't you have?
ctc 169 - 179 could be high voltage divider... need more info
Posted on Nov 11, 2008
I have a 52 inch RCA. I was watching it and
Sounds like a high voltage transformer failed.
You will need to call a serviceman to repair if your not technically handy and can solder.
Dec 14, 2009 | RCA P52926 52" Rear Projection Television
My 52 inch rear projecter rca tv model number r52wh74 picture goes black after a little wile and dont come back for awile staying off longer and longer all the time. but there is sound.
It seems that you have either a defective lamp or ballast, i recommend that you replace the lamp first, if it doesn't work it means that it's most probable that your ballast doesn't have enought voltage to keep up with your lamp. I recommend you get a Philips lamp since it's going to give you a brighter image and also it has a longer life spand 6-8 thousand hours, on the other hand, the generic lamps last 3-6 thousand hours and the image is not that bright, so if you're looking for quality get the Philips.
Jun 29, 2009 | RCA Televison & Video
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Just moved, can't find booklet....need book to set up TV
To find your user's manual just in case you've lost it. You can visit http://tv.rca.com/en-us/productdownloads.html and select your tv's size and model number. In case you don't know the tv's size I'll give an example. On the back of the tv you can find the model number. Example mine is R52WH74, that means that my projection screen is a 52 inch. Write back if this isn't what you're asking for.
Jensenka
Sep 30, 2008 | Hitachi Televison & Video
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitach 55 inch 1998
have the poser supply checked sounds like it went out
Jun 28, 2008 | RCA P52926 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
I HAVE A RCA 52 INCH SCREEN WHILE I WAS WATCHING IT THE SCREEN WENT TO A CURVE SHAPE AND THE COLORS ARE GHOSTING. MODEL #R52WH74.WHATS WRONG
you have a very common tv projector problem bad convergence
you need stk ic big chips on large silver heat sink.cost to fix from tv shop is around 250 to 400 depends who you get part are only 45.00 dollars
I hope this helps good luck
doctor video leadingedgelectronics since 1987
Apr 29, 2008 | Televison & Video
RCA R52WH73 Projection Television Logo
259 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
