Question about Poulan Ght225 25cc Gas Hedge Trimmer
Poulan Weed Eater GHT220
Engine keeps cutting off. How do you adjust the green and yellow carburetor adjustment screws ?
    Problem Solver:
There are mntwo different size fuel lines which one does the gas filter hook up to?
Posted on Aug 08, 2011
  • 48 Answers
You shouldnt have too - remove carb disassemble an flush with carb cleaner - might as well but new diaphrams in also
Posted on Oct 17, 2008
What is the proper way to adjust the high low carburetor setting on a Poulan Pro weed eater
Both should be set at 1 and a half turns out to start. Turning the screws out will richen. Turning in will lean. If its hard to start or boggs/ dies when you throttle then its lean- turn the low out another half turn. If it revs up for a minute then slows down richen up the high. At full throttle you still want to hear a bit of a cackle- adjust the high
Jul 08, 2014 | Garden
How to adjust the carby on a poulan xt 20 type 1 weed eater
If your unit is fitted with a Walbro diaphragm carburetor, use this:
http://tech.flygsw.org/walbro_tuneup.htm
If your unit is fitted with a Zama carburetor, use this:
http://www.zamacarb.com/tipspage.html
Dec 16, 2010 | Poulan Garden
How to adjust carburetor on weed eater xt 20
Here is a basic tutorial for 2 stroke diaghragm carburetors.
Nov 06, 2010 | Poulan Garden
Can not adjust carburetor
Yes...they have them on Ebay. Normally you won't be able to get one from a small engine repair place or dealer unless you're "in" with them. You can make using a 22 gauge-18 calibre electrical connector. (Quick disconnects-female) They need to be female spade terminals and you can stick um on the end of a screw driver and then push them down over the round-splined heads of the L and H adjusting needles on the carb. Probably have them at auto parts store....if not Radio Shack.
Jul 12, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
My Husqvarna 128 LD bogs down and quits running
Dirty air filter, dirty fuel system, ie carb, lines, fuel tank. Poor air fuel mixture srew adjustments.
Apr 27, 2010 | Husqvarna 28cc Gas Line Trimmer
Can't get weed eater started. Have an older weed eater brand. Fuel is getting to engine, but can't get it to start. How do I adjust the carb to get it to start. I have cleaned everything out and have the...
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Sep 17, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Needs carburator adjustment for poulan model # FL 26
Sure. (This will void your warranty and bypass smog requirements!) There is a red and a white limiter cap on the carburetor adjustment screws. Red= High speed / White = Low speed. Remove limiter caps. Turn both jets a 1/2 turn counter clockwise, Start, then fine tune. Use the low speed and idle screws to smooth out low to idle speed and the hi speed jet to tune the full throttle.
Apr 08, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan Ght225 25cc Gas Hedge Trimmer Logo
3,415 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
