Question about Brother Office Equipment & Supplies
Brother MFC 9420cn Printer not printing properly
Hi there i have a brother mfc 9420cn with a brand new black toner cartridge in it. the other toner cartidges are in the printer but empty. I only want to print in black/white.
The print out is very light and barely visable on the page.
Before sending to print i select the mono option under the colour management options.
does anyone know what the problem would be.
thanks for any help given.
keith
Mix-it-up
  • 832 Answers
SOURCE: MFC-9420CN
There is no 9 4 2 0 cn machine from brother.
Anyway if you run a ink printer from brother have a look around here:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000053/faq000253_008.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=16
Posted on Dec 05, 2007
  • 30 Answers
SOURCE: Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Posted on Feb 06, 2008
SOURCE: Brother MFC 9420CN
hi wensum....
i am vj_tech guy. plz download drivers n install them from the following site. select the operating system n start installing.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:582:0:0
Posted on Feb 25, 2008
disastertech
  • 62 Answers
SOURCE: brother printer mfc-9420cn says to
when you open the front cover, there is a waste toner tank on the bottom right side of the printer.
Remove the tank and chuck out the waste toner, wipe the tank clean with a cloth and slide tank back in position and close the cover.
this wil resolve the message on the screen
Posted on May 14, 2008
SOURCE: change time on Brother MFC-9420CN
laoding is too slow, It did very fast but now is too slow what happen?
Posted on Apr 03, 2009
Brother mfc-9420cn unabel to scan
I work at Office Depot. Bring it to one of our stores and we can look into it and diagnose it. Usually it is as simple as a loose toner cartridge.
Dec 14, 2011 | Brother MFC-9420CN All-In-One Laser...
If i have run out of cyan coloured toner, can i print only black somehow? the printer doesn't want to print at all (even on mono colour selection), and keeps asking to replace toner cartridge
There are few printers if any one toner ink is finished it does not print any more. So you must replace the toner or refill it then it will work.
Jun 12, 2010 | Brother MFC-9420CN All-In-One Laser...
Lose of coloron one side
Try cleaning the toner drum with a lint free cloth.
May 26, 2010 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9840CDW not printing colours properly
Always use Brother toners. This is a common issue with cheap copies and remanufactured cartridges.
Jun 08, 2017 | Brother MFC-9840CDW Laser Printer
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
Mfc 9420Cn printing but marking black line on
try making a copy off of glass. if black mark is gone, then you have to clean the narrow strip of glass to the left of big glass.
hth,
razors
Apr 15, 2009 | Brother MFC-9420CN All-In-One Laser...
Printer is not printing clear and nice pictures
Dear Cubohr,
You need to check the other colour toners, if the other toners are running low, than you will find that the black tone becomes more prominant in your prints. Alternately, there may be an environmental condition with your unit. If it is in direct sunlight, then it is possable that you are getting light interference on all your prints. There are also a number of other reasons.
Check your toners first, check if there is light interference, if both are ok, your unit may still be under brother warranty and you may need to get it to a brother service centre.
Gremlin11
Dec 10, 2008 | Brother MFC-9420CN All-In-One Laser...
Help with Brother MFC-8500 all in one printer
When you get the paper, can you smear the print with your fingers, or is printed on there properly.
if you can smear it, it would be your fuser not doing its job properly, if you cant, then its your replacement toner as it most likely incorporates the drum in it, which i think is your problem.
Jun 20, 2008 | Brother MFC 8500 All-In-One Laser Printer
Color cartridge
The Brother machine will not print if the message "Toner Empty X" ( X =C for Cyan, M for Magenta, Y for Yellow and K for Black) is displayed on the LCD. The empty toner(s) must be replaced in order to continue printing. Incoming faxes will be stored in the memory until the toner(s) is replaced.
May 10, 2008 | Brother MFC-9420CN All-In-One Laser...
Blue Toner finishes quicker
I can't imagine where toner could possible go from one of these sort of cartridges except on to your paper, I had a customer once with the same request and I found on their letter head that they printed with it had a single band of yellow across it hence excess yellow use,,,,,, Do your print runs of anything contain dark bands/underlines? I guess check to see if white background in any prints has a blueish tinge to it, or possiblly somehow black is running out and it is printing the blacks by mixing the colours (Check black block and text to see if it is really black not heaps dark blue to ensure black toner is operating)
next I'd be questioning if cartridges where brother ones?
Nov 20, 2007 | Brother MFC-9420CN All-In-One Laser...
67 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
