Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
HP Pavilion ZV5000 Charger
Hi! I have a HP Pavilion ZV5000 and when i plug it to the AC it doesn't charge. I took it to a technical service and they fixed it telling me that it is a factory problem in many notebooks of this model. The problem was that a little piece of the motherboard that is connected to the port of the charger is broken so they weld the piece. Now, after 2 years i have the same problem but worse... It doesn't charge in any way. Before I had to bend and strain the charger but now, the charger is peeled and every time I had to bend to a different side. If anyone have a permanent solution for this, please TELL ME! I can't use my notebook!!!
  • 1 more comment
  • mark_hirt Dec 06, 2008
    My HP ZV5000 will not work with the battery, I purchased a new battery and it still wont work, only with it plugged in.
    gpa
  • bluesbabe78 Jan 05, 2009
    i have a hp pavilion zv5000 i plug in ac adapter into laptop but it wont charge if you move it about charger flicks on and off but wont stay on to charge. help me please is it my laptop or the ac adapter ????
  • Anonymous Feb 11, 2009
    I have a HP E9002. or something like that, i have the exact same problem. i have to have the port that goes into the laptop elevated so it charges. I have tried other chargers in my laptop but they all have the same problem, Any Ideas
HP has a cord that plugs into the right side of the zv5000 that is intended for use with a docking station that they sell separately. The connector has a blade with a bunch of connections, but I only use 2, power and ground. The outermost contacts are power +and-. I bought the cord - re-wired my power cord to the new cord power wires - takes some figuring to determine correct wires - soldered them up and it has worked great for 2 years - much better connector also - squeeze side tabs to plug in or un-plug. This solution was about $25 if I remember - compared to $135 that the shop quoted me to replace the internal MB power connector
Posted on Apr 14, 2009
  • 3 Answers
I have the same problem, it isn't the charger, it is the DC jack on the computer. If you get it repaired, it will only happen again. The best solution is to find an "XC1000" all in one media cable which plugs into the expansion port (should be on the RH side of your computer). That way, you bypass the DC jack, and your computer charges through the expansion port. The only problem with this solution is that the XC1000 cable is hard to find. If HP still manufactured these, they would be a hot seller (definitely more profit with this than selling computers!
Posted on Jan 04, 2009
Have the same problem with mine right now... the best thing I found is to jam some paper towels right underneath the bulky end of the power cord going into your computer. This will prop the power cord up in the computer's input. You'll know when it's inserted correctly when the little charging light stays on and doesn't blink or go out (unless your battery is full).
You'll have to re-do the paper towels every couple months or so.
Not the ideal solution, but definitely the cheapest.
Posted on Apr 10, 2009
    Scholar:
  • 83 Answers
You replace your charger. It was the problem. Have you tried other charger to check if your charger is still working? If the voltage output will be the same, they will have the same work in any port of the notebook. Just check if the positive and negative terminal of the charger are the same with your present charger.
Posted on Nov 09, 2008
How do i get my hp pavilion zv5000 to run on ac power only. it will only run on the battery.
Zv5000 Laptops are plagued with problems related to the jack on the back of the computer. After prolonged use the jack tends to make the solder joint loose. Jacks can also go bad. The solution would be to check if the power comes on momentarily when wiggling the plug in the jack, if the power comes on intermittently then chances are you have a loose solder joint and may need repaired by a qualified tech. Fortunately, for the technically savvy this may be done carefully provided the proper static sensitive precautions are taken, due to the fact the computer must be totally dismantled to get to the jack and properly inspect the solder connections and repair or replace the jack. Silver heat sink compound must also replace the silicone on the processor ( one dab and compress, do not spread compound!) The jack need should it be replaced can be found on Ebay
Aug 05, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
My Hp pavilion zv5000 power fail and goes on battery mode, i have to plug and unplug to make it work, please help
The first thing to do is test an another charger,
maybe a workshop let you try theirs to get your problem sorted out.
if it works fine with the other charger, then its just to buy a new one.
if the same problem still exists with an another charger,
then its your charger connection solderings that are loose.
To prevent further damage to the motherboard
you must leave it to a workshop for resoldering the charger connection on to the motherboard
hope this was any help,if helpfull, Please vote!
May 14, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
Ac power problems
For $75.00 bucks I wouldn't even open it up... lol Thats a good deal if they do a good job. Thats a fair price too I charge like $65 - $80 and hour depending on what is being done. remembering of course we often in actuality often work on something for 6 hours, and only charge 2 - 3, because a job is worth what a job is worth.
Jan 31, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion zv5000 - No power with battery in.
the jack is the problem it is not getting enough power to laptop
Nov 02, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Laptop
please check first that does the notebook work fine on the battery mode.
if system does not work on battery mode also it is a fault of the board that would have to be replaced
if it works fine on battery, then the problem could be with the adapter
to check the same, please try using another adapter or the same adapter on another hp notebook.
if the adapter does not work on another notebook, please get the adapter replaced.
Jul 26, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Inbuilt mouse does not work
try reinstalling the drivers for it by going to the device manager.Also you can try using it in safe mode and see if that works.Incase is does not work over there than you would have to get it replaced
Dec 21, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
1,999 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
