Question about Dell E773C 17" CRT Monitor
Dell 17" monitor
Periodically, the contrast menu will appear on the screen by itself. When the exit button is pushed, the contrast menu will disappear for a few moments, only to reappear again. This will usually happen 4-6 times in a row, and then the problem goes away for a while. Is this a known problem?
  • 5 more comments
  • Anonymous Dec 04, 2007
    I agree that the problem is the button. I just had the same problem. Having the contrast menu pop-up is a pain as it is "always on top" I think I have it fixed. This is what I did. (Don't be stupid and take the case off BTW - You could get zapped - even if it's unplugged (capacitors)) I got a Heavy duty vacuum put the nozzle right up to those 4 buttons, and tapped on the buttons (it got the dust out of the contacts behind the buttons) repeatedly, Problem went away. I hope the contacts stay clear now.
  • snehroo Jul 24, 2008
    Periodically, the luminance menu will appear on the screen by itself. When the exit button is pushed, the luminance menu will disappear for a few moments, only to reappear again. Is this a known problem?
  • Starrymom3 Aug 30, 2008
    The Contrast bar keeps coming up on my computer. We tried resetting it, but I have a block on my computer that says Contrast in red, a red bar, and under it 100. It goes away, then comes back. If the button is stuck, how do I unstick it?
  • mac2life Oct 09, 2008
    My monitor displays the contras and somthing about Luminance Temperatura on screen.. HOw do I get this to go away forever? It gets on my nerves...
  • Anonymous Jan 05, 2009
    my monitor displays the same messenge, but it is AOC
  • perfumatto Jan 19, 2009
    My monitor displays the contras and somthing about Luminance Temperatura on screen.. HOw do I get this to go away?
  • sailudavey Jan 20, 2009
    the "luminance temperatura" stays in the middle of the computer screen and refuses to go away...even changing the resolution does not help!! somebody please find a solution to this!! any help will be greatly appreciated..!!
  • 3 Answers
I had a simalar problem with my Dell 2001FP. The issue is that there is false triggering of the switch; you need to open the front panel, and electrically remove the swictch from the circuit by: 1) analyze the circuit; its usally pretty simple - a voltage drop circuit. 2) disable the switch by either removing it with a solder gun or, simply by using a sharp blade and cutting the PCB track leading it to it, as I did.(much easier - and reversible!) Fixed my problem.
Posted on Dec 17, 2008
I believe what you have here is simply the contrast button being stuck. Hope this helps
Posted on Jun 29, 2007
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E173FP main menu flashes on randomly
it happens due to excess moisture in air when the switch gets shorted by itself due to dust accumulation ,If in warranty pls log a call or else get it checked by a monitor repair person all monitors have same switch's
Apr 07, 2013 | Dell E173FP 17" LCD Monitor
The brightness/contrast menu keeps popping up and scrolling through the exit, brightness and contrast options. It is a Dell E173FP monitor. I have tried disconnecting and reconnecting the cables and...
Try pushing the buttons for the brightness if it does the same thing you need to replace it, the buttons might be damaged already by pushing too hard or it got stuck.
If this is just a new LCD monitor about 1 to 2 years old contact tech support of dell so you can get this replaced.
Jan 30, 2010 | Dell E173FP 17" LCD Monitor
Screen too bright, have just got monitor from e-bay and there are no instructions on use.
Check all the buttons near the ON/OFF button.
One of the buttons will activate the OSD (On Screen Display).
The OSD controls everything about the monitor, including BRIGHTNESS and CONTRAST. Use the other buttons to move between menu-items, and to "select" one of the sub-menus, and to raise/lower settings, and to "exit" from a sub-menu to the main-menu.
Nov 18, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Black box in middle of screen
Push your memu button and it should disappear.If that doesn't work, contact Dell.com and they will talk you through it.
Sep 14, 2009 | Dell E173FPb 17" TFT LCD Monitor
The contrast adjustment screen appears all the
Sounds to me to be either a failing button position replacement spring in the button itself. This problem also could be caused by dirt buildup surrounding the hole in the monitor bezel where the button protrudes. Try using a dental tool or something small and pointed to clear any possible debris from the buttons edges. Also some canned air may help. If these things don't fix your problem the bezel may need to be removed for a more thorough cleaning. If you are able to make it dissapear by pressing the button it most likely isn't hardware failure causing your problem, as those buttons are rarely used.
I hope that this helps fix your problem.
Good Luck
Jul 28, 2009 | ViewSonic E70f 17" CRT Monitor
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Contrast Menu appears after switch On
Contrast Menu appears after switch...
Jan 02, 2008 | Philips Standard 105S Monitor
Dell E773C 17" CRT Monitor Logo
1,823 people viewed this question
Alun Cox
