Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
TV has power but no picture.
I have a Toshiba 42H83 Projection TV. The power goes on with red led but no picture on screen. I opened up the TV and check for blown fuses or busted soldered component but coudn't find any. Question: 1. Any particular component I should be looking at? 2. Can I fix this myself? 3. How much would it cost to fix this TV? God Bless.
    President:
  • 3,130 Answers
If you know how to read a schematic diagram and have the proper tools then you should be able to fix the set. The first thing and most common for your symptom is a bad regulator IC in the main power supply It will be standind up on a heat sink and start with STR and have 4 numbers after it. Now it could also be a problem in the sweep circuit but not to many faklures there. I have seen once that a blow audio output IC shorting out cause the entire set to shut down and it did take out the regulator IC with it Too. A shop repair for a set like this can run around 250 all the way up to 500 bucks depending on what the fault is. Hope this helps ya. Good Luck
Posted on Jun 03, 2006
My toshiba 42h83 tv has sound but no picture
of course check different inputs etc to make sure something did not get disconnected.
This rear projection set uses 3 picture tubes and the set will protect them if there is a problem in the vertical or horizontal sweep circuits that might burn the screens or the damage the tubes.
No simple answer as a lot of different parts are possible for this problem.
Apr 27, 2012 | Toshiba 42H83 42" Rear Projection...
Control board say not availible when any button is pressed, only shows av1 picture and picture is scrambled, toshiba 42h83 modle rear projection tv
this may be due to a stuck on mode select button control, are you going to try to repair yourself ? do you have a shop manual ? let me know
Jan 30, 2010 | Toshiba 42H83 42" Rear Projection...
My toshiba 42h83 has a shaking picture with a 2 to 3 " green stripe at the top of the screen. How can I fix this?? thank's Karl
Check all wires cables go to the tv,shakes,jiggles might,see the prob.than change the wires cables.Not wires cables,than ur main video board is the prob.must change.
Oct 27, 2009 | Toshiba 42H83 42" Rear Projection...
Picture dark
Please check its G2 (grid) volts, should be approx 600-700 volts dc. In some sets it calls Screen Volt.
Aug 09, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Red spot in the middle of the screen
You most likely have a burn in on the surface of one of the picture tubes. What you need to do to confirm this, would be to take off the front screen, and with the set turned on, look directly into each one of the lenses, and see if you see a mark on the green or the blue tube. if this is the case, and I am pretty sure it is, the picture tube will need to be replaced, but this set is not a young thing, as the green faint lines is most likely a bad capacitor in the screen drive circuit. If the picture tube is indeed burned on the surface, most likely be better off buying a new TV set. Good Luck
Jun 25, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42wh36p problem
you tv problem intermittent the problem is in the color circuit, vertical circuit.have a tech check your tv for repairs.good luck.
May 18, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
