Question about Goodman Heating & Cooling
I have a Goodman split unit installed. The inside furnace works fine. When the system is turned on the outside unit makes a slight "popping" sound like the current is getting there but the fan will not start. I have replaced the capacitor but it is still doing the same thing. Please advise. Thank You, Dan Clevenger. Dan@gwwyatt.com
    Sergeant:
  • 320 Answers
Change the circuit board of the system... no other option.. and also check the electric contactor switch... Have any other queries, please let me know..
Thank you.....
Posted on Oct 17, 2008
    Brigadier General:
  • 3,614 Answers
check the electric contactor switch. if you say that the fan was not working. first check this part.
    Genius:
  • 1,550 Answers
You need to change the circuit board .
How old is your air conditioner ?
Want to reinstall...split system heat pump and gas furnace both goodman
What is current refrigerant being used in the system being replaced? What are the sizes of the existing breakers for the Air Handler, and the outside unit? Do you plan on replacing cooper lines ? Use drain line already there?
o
Dec 05, 2015 | Goodman Heating & Cooling
What does code blinking five times mean
need to read inside diagram, will tell u what lights mean.
Jul 10, 2013 | Goodman Manufacturing MSG12CRN1N -...
Unit wont start and error code led is blinking five times
Check the unit from the outside. This happened to me: 1.) The unit was not raised off the ground 2.) Rodents had chewed on it. Or it could be: 3.) Replace batteries 4.) The unit will not work off season when it gets too cold to use the cool air option.
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
Just cut on 8 year old Goodman CPLE24-1 AC for the summer. Ran 8 hours fine, Next morning noticed outside unit running, very little cool air blowing out of inside floor vents (like the blower fan was...
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know.
I think I have it covered above. Let me know if you need something more specific. Thank you. Roger
Apr 12, 2011 | Goodman CPLE24-1 Air Conditioner
#model-cple48-1 split unit sometimes inside fan dont turn on,appears to be circuit board in outside unit#b12260-08 is this still available.
Can you set your thermostat to on instead of auto on the fan? If this fixes it it would be a loose connection at the themostat or broken wire. (broken wires are very common and they will make and break connection they break because the copper wire is small and it gets scored when stripped) I do not see a way the outside unit could cause your problem. If it was any circuit board it would be the one in the furnace.
Aug 03, 2010 | Goodman CLQ36AR49 Air Conditioner
Had a Goodman heating unit installed in Oct. 2009. Recently tried to turn ac on .but no action. Installer returned and hooked up some wiring which got fan working but no cold air. The outside compressor...
It sounds like the outside condenser wires are still not hooked up correctly or there is a problem with the 24v electrical inside the unit. Describing what you have, I'm just banking on the connections. Now, if you have a heat pump system, there will be more wires and a little more difficult, but a normal split system will have two wires going from the furnace to the condenser. These two wires should be hooked to the Y(Yellow) terminal and the C(COM) terminal on the board inside the furnace. If it is a air handler unit, then it needs to be connected to the Blue and Yellow wires. The two outside condenser wires can be hooked up either way, it doesn't matter. I hope this is a simple fix for you and not something more. Good luck and I hope this helps.
Jul 04, 2010 | GE AJCQ08ACB Air Conditioner
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
Ruud A/C condensor unit won't come on
It sounds to me that the wire going to y2 on the furnance coming from the thermostat was not wired back up this is the wire that supplies control voltage to the contactor on the condensing unit. I would call the installer who changed the furnace out back to remedy this problem.
Jun 01, 2008 | Heating & Cooling
Central heat unit not blowing
Is your unit a Split system where one unit is inside (attic, garage, utility room) and another outside?? Is the outside unit unit running?? Is your thermostat electronic or the regular slide mechanical type??
Jan 17, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
