Question about Samsung VP-D20 Mini DV Digital Camcorder
Battery charging I recently charged 2 x 7.4v batteries, and the green charging light lit and flashed (although I didn't count the rate of flashing) When I began using the camera to record, it only operated for about 2 minutes, then would not record or play again. Later, I was able to operate the camera with the charging lead plugged in, but again, only for a very short period. Now it will not operate in any mode, and the green light does not come on. There is power coming through the charging lead, and I am now beginning to suspect some kind of broken or intermittent contact. Any suggestions................???
  • 1,476 Answers
When you initially used the unit was it with the battery or not? If it was with the battery was the AC hooked up also? You need to remove the batteries from the equation to find the problem. Hook the camcorder directly to the AC unit and see what it does. Also you do not mention how you know that the AC unit has power at the lead. Checking with a DMM does not garantee it. I have seen units which have the correct voltage until you put a load on the AC adapter. At this point the AC adapter could be bad, the battery could have a memory or be bad or the input jack could have a bad solder joint. If you have a DMM and know how to use it check the AC adapter for proper output. If it checks OK you will have to assume that it does not have the problem I mentioned. I have only seen that one time. With no battery on the camcorder, plug the AC adapter in and try the unit. If it does not work you probably have a broken input jack. If you are good with tools, have jewelers screwdrivers, magnifying glasses, a steady hand and lots of patience remove the covers to expose the jack and repair the connection. This should solve your problem. If you are not capable of the repair you will need to find a good reputable repair facility to take care of this. Cost should be less than $100 US. Good luck.
Posted on Jul 25, 2006
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
Battery not charging
Sounds like it could be two things with that, first look at the battery symbol, is it flashing orange or is it green. If its flashing orange means you have a bad battery, if its solid green all ok, if its switching between green and yellow its charging. if the symbol isn't lit at all it doesn't detect your battery and try to remove and reinsert battery. Next look at the plug light, is it green?
Dec 16, 2012 | Lenovo IdeaPad Z560 Notebook
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
May 14, 2011 | Health & Beauty
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a Dell Latitude D600. It will not charge from the charging port in back. It will charge while on the dock. There is always a flashing error code, I assume, on the charging LED. It flashes 4 red and...
Don- I went to Dell support and without knowing a service tag #, I looked your laptop generically. Here's a link to your owners manual: http://support.dell.com/support/edocs/systems/latd600/en/ug/index.htm The only thing I could find about "light error codes" was in the solving problems category. I read something that said your battery/laptop is too hard to charge. I replaced the motherboard recently in a friends d800 because the power jack had got pushed in and dislodged from the motherboard,then wouldn't charge the battery. Although she had no error codes OR a docking station.You said you replaced the battery and the cord. Did the new battery/charger ever work right? if no, why didn't you take it back? Is it still under warranty? Without more info, best I could come up with. Hope this helps and good luck.If I helped please rate me. Thanks -jmattes
Oct 17, 2009 | Dell Computers & Internet
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Samsung VP-D20 Mini DV Digital Camcorder Logo
122 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
