FixYa.com
Tags:
Samsung SD 616E  Internal DVD Drive
Unable to read some of the DVDs...... (by 8 users)
posted by Raed on Jun 03, 2006
hi,
I have some of my DVDs (Media or Software) that Sumsung DVD-ROM SD-616E is not able to read, getting some massege something like (unreadable CD format or the cd is not capable with Windows format).
keeping in mind that these DVD are readable in othere DVD-ROM in my PC.....
so i tried to find some updates in google, and i found some latest firmware, but nothing happened, i tried to change the DVD-ROM region, but also nothing.
Hoping to hear from you soon,and know whats going on and what i have to do....
Thank you,
Raed
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Comment by Guest, posted on Apr 17, 2008
Dear Sir,
I am unable to read other Media File and Cds,
Pls give the solution for this,
soma
Comment by Guest, posted on Apr 07, 2008
My DVD writer can read or write cd's but comming to DVD's it neither reads or writes them when i try to insert dvd while writing any data dvd then nero burning software reads dvd as cd-r plz help me
Comment by Guest, posted on Apr 02, 2008
The problame is same. Also the it indicate that a "Power DVD Software" is requred. But unfortunatly, the CD containing the said SW with me , some portion of the SL number has been erresed.
Comment by KLISTER, posted on Jan 09, 2008
[SPANISH]
Exactamente tengo el mismo problema, algunos DVDs no me leen, incluso DVDs originales de videojuegos o películas. A veces, estoy visualizando una película desde el DVD y se queda la unidad leyendo.
[ENGLISH]
I have exactly same problem. My LG DVD unit have very troubles for read some DVDs. I have revised the drivers. Drivers have do not troubles, but the read/write problem persist.
Comment by Guest, posted on Dec 19, 2007
Dvd Drive cannot play video DVD
Best Solution
posted on Jun 03, 2006
Helpful (85)
bmwrider
Rank:Wiz Wiz
Rating: 85%, 1741 votes
It's possible that the drive has died. CD and DVD drives are notorious for short lives but then I've seen some last 5 years. The lens could be dirty, just a small piece of lint is enough to cause hassles. Try using a Lens cleaner, available from all good audio shops. Some machines don't like +R disks and a firmware upgrade is needed. I've done many Liteon Drives with terrific results but if the manufacturer hasn't put one out then you're lost. It's possible you've used the wrong upgrade to fix your problem.
With the prices of drives today it's sometimes cheaper to replace it. Believe me they can die quickly, my record is a week from brand new to unuseable and that was a Sony.
BMW
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 03, 2008
Not Rated (0)
guddu91p
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i play the lens cleaner but still i hv the same problem??????
plz help me now.................?????????
Solution #3
posted on Jun 21, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
my computer cant play dvd its not installed
Solution #4
posted on Feb 15, 2008
Not Rated (0)
fazal nadeem
Rating: 0%, 0 votes
lenz repair two veryable adjust dvd setting
Solution #5
posted on Nov 12, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Another possible problem is that I have run into problems where certain drives could not read certain disks. This could be because of problems with the laser, firmware, scratches, or any combination of those. Usually the quickest easiest way around a problem like this is to make a copy of the disk using a drive that reads it without any problems. This would might or might not work. In any case I would recommend getting a new drive.
This Problem Also Relates To: HP (198702-001) Plug-In Module DVD Drive HP (280751-B21) Internal DVD Drive HP (5185-4862A) DVD Drive HP (A5557AR#0D1) Internal DVD Drive HP (A8069A#0D1) Internal DVD Drive HP (A8682B#0D1) Internal DVD Drive HP (AA620A) Internal DVD Drive
Can you Help with these DVD Drives problems?
DVD Drives
donskydats@yahoo.com
My philips dvdr1660P1 driver in... Answer This...
DVD Drives
Changing drives
We have a CD drive, would like... Answer This...
DVD Drives
instilization for drive
is there anyway you could give... Answer This...
DVD Drives
burning Mp4 files to DVD
Why can I only burn around 20... Answer This...
DVD Drives
D:\ is not accessible incorrect...
Every time I try to use my D:\... Answer This...
7 Other Users Have The Same Problem - Continued
Comment by rbrown52, posted on Dec 17, 2007
I have a similar problem. One day the drive stopped reading data CDs, music CDs, or DVDs. The disk goes in, the light flashes, but no action. Headcleaners just don't work so the Samsung now has a date with the recycling centre. Probably best to buy a brand that has a longer lifetime than 2 years that has been shared with another DVD device on the machine.
Comment by Guest, posted on Nov 10, 2007
My PC doesn't seem to detect ANY DVD's at all. It reads CD's but not DVD's.
I've tried tonnes of things such as changing the DVD rom region and other stuff
please help.
Repair Service
Find DVD Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
