Question about Philips 42PF9630A 42 in. Plasma Television
Menu keeps coming on .
The menu keeps coming on and covering the program i am trying to watch. When i turn the power off, the program comes back for a few seconds and then the menu screen comes back on. How do i get this to go away? The menu keeps coming on when I turn the tv on. It will go away momentarily when I turn it off and on, but goes right back to the menu.
Also I cant get the menu to respond the way its supposed to, so I cant go through it and see if there is a way to cure this issue
    President:
  • 1,952 Answers
First check for a short in all power semiconductors diodes, transistors, SCR, etc. Replace defective parts. The FBT coould also be defective. Check the voltage on each of his pins.
TV Repair
Posted on Oct 17, 2008
    Sergeant:
  • 320 Answers
this is very common. the ebuttons are bad on the tv and need to be replaced. i do these all the time. a charge might range 100-150. i know the buttons do work. what happens is they get what we call (leaky) they send partial signals causing the micro (the tv's brain) to think it is getting a signal and this can turn the tv on/off menus scrolling channels volume up or down.i just fixed one of these on tuesday and see two or three a week.it is even a techincal bulletin on a rca tech web site
on some rare cases i have seen bad connections around the micro cause this.
let me know if you need more info here.
Thank you.........
  • Nagesh V Oct 17, 2008
    And also try removing the betteries of the remote and turn the TV on.. Then see os the same problem occurs or not.. Have any other queries, please let me know..
    Thank you.......
  • Nagesh V Oct 20, 2008
    You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
    Brigadier General:
  • 3,614 Answers
What is the unit model, and did you use the remote control or the panel of the tv in turning off or to exit the menu...?
  • micromaster
    micromaster Oct 17, 2008
    first try to remove the remote battery and turn ON the tv set. see if still the menu will show again.. if you have solved and see that the menu is not showing anymore, it is now time to replace and have a new remote..
    let me know
I have a phillips tv model# 42hf9745d/27 I was watching tv and the power turned off tv I turned it back on the standby light comes on green but no picture need help to solve problem please.
Sounds like it could be a power surge issue. When the power came back on it could have over loaded your TV shorting out parts of the tv.
Does anything come on the screen at all? Do you get a logo when it turns on? Can you access a menu at all? Can you try plugging in a different device (DVD player etc) and get a signal?
If you're able to get a menu or logo to come on, then it could be a cable issue. Check that the cables are secure on the TV and other devices. If they're good then the TV is most likely fried.
Jul 11, 2016 | Televison & Video
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
Hi! My Toshiba 40RV525u TV has a problem, it turns off or on by itself. I checked the auto power off settings, the time is not set (it is 00:00). This happens very randomly. Now I just plug out in the...
My TV 40RV525U changing channels, menus itself for few months.
later, it turn on off by itself and unable to hold on a channel ( I use antenna)
What I did
Remove back cover.
DONE.
Jan 14, 2011 | Toshiba 40RV525U 40 in. LCD TV
The plastic piece that keeps the battery in place is broken.(F16059/4) is the watch
mcdevito75 here, This is a piece of plastic is used betwen the battery and the back cover of the watch as without the plastic there is a small gap between the battery and the back cover, meaning the battery could come loose in the watch even with the back cover on the watch, replace this plastic piece with some carefully folded Scotch Tape, cut and shape the Scotch tape to Approx. the same size and thicknesss of this piece of plastic or just by sight thick enough to keep the battery in place in the watch with the back cover on.
Aug 18, 2010 | Watches
Toshiba 40rv525r screen says NOT AVAILABLE
I've had the same issue! This is caused by the control panel telling the TV what to do - does it change channels on its own, too, or turn off or on on its own?
What you need to do (if you've not already done it) is lock the control panel out, which you can do under the LOCK menu.
What may help is running the factory reset on page 54.
Mar 22, 2010 | Toshiba 40RV525U 40 in. LCD TV
Recorded programs in english come out in Spanish
Make sure your TV hasn't been set for SAP (you'll find it in the audio settings menu). Second audio programming is often used to carry alternate languages, and if it's turned on you won't know it until you watch a program where it's being used. There may be a single button labeled SAP on the remote. If so, it's easy to change the TV setting without realizing it.
Feb 06, 2009 | JVC AV27F476 27" TV
Set up menu
Your set could be losing the 5v to the system control chip, or the keys on the remote or front panel may be sticking. You could also have a power supply with diodes or capacitors that are dying.
If you don't know how to service this, don't even bother opening the cover.
tom
Sep 05, 2008 | Proscan PS27108 TV
Thompson dti6300 twin freeview box with 160 gb hdd.
When box freezes turn box off at wall for 30 seconds then turn on again, when red light comes on carry out the following.
  1. Press menu
  2. Press 4
  3. Press 6
  4. Type in 1397
  5. Scroll down to item 7
  6. Move across to change to yes
  7. Press library
  8. Highlight corrupt program
  9. Press blue then green
  10. It can take quite a while to delete
  11. Press back to come out of menu as to need to follow this procedure for each corrupt program
Jun 30, 2008 | Televison & Video
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Philips 42PF9630A 42 in. Plasma Television Logo
456 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
