Question about HP Office Equipment & Supplies
Scanner won't scan- will print - HP Office Equipment & Supplies
    Problem Solver:
  • 5 Answers
Try to reprogram your printer into your computer
Posted on Oct 17, 2008
2 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: lexmark x4530 multifunction printer/copier/scanner. The
    There could be something blocking the scan communication - possibly a firewall. If you have a firewall enabled on your computer, make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
    Posted on Jul 01, 2011
    Sharp mx2300n tray 3
    Sounds like you need to configure your print driver with the options that your machine has on it.
    Check out my instructions on how to do this!
    How To Configure Sharp Print Drivers with Installed Options to print...
    Apr 30, 2013 | Sharp Mx-2300n Copier Color Mx2300n...
    Won't scan, error message -scanner door is open
    Simple solution. I just had the same problem. Make sure the top cover on the left side is snapped in. It wasn't obvious that it was open. They should probably give a better code because it is not the scanner door that is open.
    Apr 16, 2013 | Samsung New-scx-3405fw Wireless...
    Barcode scanner won't read printed labels
    1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
    2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
    3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
    4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
    Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
    CANON PIXMA SCAN CODE 2,151,44
    I have a PIXMA MP340 printer/scanner--prints fine but when I try to scan, it gives me error code 2, 151,44.
    Nov 06, 2012 | Canon PIXMA Office Equipment & Supplies
    Hp c4580 on mac 10.6 won't scan
    Based on the information you gave this may help:
    Go to 'system preferences'
    select 'print and scan'
    Above the picture of the listed printer select 'scan'
    Then select 'open scanner'
    Follow onscreen directions from here.
    Jun 08, 2012 | HP Photosmart C4580 All-in-One InkJet...
    Kyocera CS-C2525 won't scan
    Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
    May 22, 2012 | Kyocera Copystar CS-5035 Copier
    MY SCANNER WILL SCAN PRINTS BUT NOT TRANSPARANCIES THE SCANNING LIGHT WORKS ON PRINTS BUT NOT TRANNYS, ANY IDEAS PLEASE
    Flatbed scanners that can scan prints and transparences had two light sources.
    One for normal prints (ie reflective light source, the light shines from under the glass to the print/photo and reflects off this print/photo to the optical sensor).
    On a scanner that can scan transparences there is a second light source in the lid that shines through the transparences pass the glass to the optical sensor. The light source under the glass is not used in this case.
    The scanning software automatically selects the right source when you select to scan prints or transparences.
    Sep 06, 2009 | Umax Astra 6450 Flatbed Scanner
    Officejet 6110 all in one - printing problem with Mac Os X 10.5
    I suspect this is not the printer problem. The problem may be the operating system issue. (Memory management)
    Regards
    Rafique
    Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    113 people viewed this question
    Seeker5211
    Seeker5211
