Question about Goodman Heating & Cooling
I, have goodman a/c unit model PGB024075 & the red ligth blink 6 times
5 Suggested Answers
  • 7 Answers
SOURCE: no power red ligth blinking 6 times
The problem is the thermal fuse. You need to have service bulletin to fix it. I have seen other people have the same issue and it was fixed by getting the SB at agoraquest. It's a step by step guide on replacing the thermal fuse. The member that has the service bulletins is Jehill. He has helped several people with this issue
http://www.agoraquest.com/viewtopic.php?topic=24322&forum=34&start=0&select_page_number=1
It takes about 2 hours but saves over $400 in service repair bills.
Here are some of the people that were helped by this
J/K :-p ......worked like a charm :-) Took me about 2 hours and almost half of that was to go and get a 20" #2 philips screwdriver. A 12" would have worked, but they did not have it. Other than than that, no problems. I paid $220 for the TV, $28 for (2) Thermal Fuses, and $11 for a screwdriver. Now I have a decent 2nd TV :-) Not as good as my KD-34XBR960, but not much is :
Happy
I just got done replacing the thermal fuse as per your SB and all is well again! I, and most importantly the wife, just want to take the time to thank you so much for your help. With your instructions and this site, we have just saved ourselves alot of $$ not just for this time but also if it were to happen again in the future. I am truley grateful for finding this site and just want to say you are THE MAN!!!
pratt31
1 10" screwdriver $12.00
1 Sony Thermal Fuse + shipping $ 8.00
1 membership to agoraquest.com $12.00
Fixing the thermal fuse myself on a TV that was discarded at the curbside
PRICELESS
Posted on Apr 14, 2008
  • 306 Answers
SOURCE: need to know how light pilot
First step turn the thermostat off. It is very important.
Next find the knob on top of the gas valve you will see writing on it turn it to pilot it could be in the off position so move it to pilot depress the knob where it goes down about one inch. Take a long lighter long match or something like that and hold at the pilot it will be back in the furnace by the front of the burners. Once the pilot lights hold the button for another 30 seconds. Release the knob now the pilot should be on and the next step is why you turned off the thermostat rotate the knob to on position. Go to the t-stat and turn on the heat.
Posted on Nov 27, 2008
  • 148 Answers
SOURCE: RED BLINKING (6TIMES) ON FURNACE
THE ROLL OUT SWITCH IS LOCATED IN THE BURNER COMPARTMENT MOST CAN BE RESET
Posted on Jul 20, 2009
  • 17 Answers
SOURCE: hp compaq 5700 beeps 4 times with a red blinking
You have to check your ram .
Posted on Mar 05, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: goodman furnace model#GCH90904CXAB the red light
This model is equiped with a diagnostic error control. Take off the front panels and look for a wiring diagram pasted on the reverse side of the panels. On this diagram there will be a chart telling you what 4 blinks represent and where to start looking for the issue. I suspect the air filter may be dirty or the pressure switch may be bad, however make sure the condensate hoses are free of any debris. Good luck to you!
Posted on Apr 25, 2010
Sony kdf-55A20 blinking red ligth 6 yimes. How to fix.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Type in the brand name and type of your device, in the search box [at the top right] of the display window. It will make surf easy.
Jun 23, 2015 | Sony Televison & Video
Sony wega projection tv. kp524-m91 red ligths blink 6 time then pause then repeat again. and after 30 minutes it will open. what is 6times red blinks error code
it could be a thermal fuse. look for a professional repairstation,
it not build in a box? give it some fresh air. perhaps it will work.
May 03, 2015 | Sony Televison & Video
Standby ligth blinking 6 times pause and blink 6 times and so on , no picture and no sound
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Apr 29, 2012 | Sony Televison & Video
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
The tempeture ligth start blinking red in the morning and it beeps about 6 times and then the ligth turns off
Check coolant level in bottle.
Check for updated CTS ( Coolant Temperature Sensor.) in hose at rear of cylinder head.
Check for coolant creeping up loom from coolant res; bottle.
Check Grounds under battery.
Jan 05, 2011 | 2000 Volkswagen Beetle
Green ligth comes on and then gose off, proceed by red ligth flashing.
Hi:
If you count the number of times the red light blinks before pausing and starts to cycle over again. This is the error code the unit is producing. Also if its been a while since you replaced the lamp then it may be time for a new one. Check the lamp housing and pull out the lamp it may be shattered. You can find the lamp area and installing instructions using you onwers manual.
Nov 10, 2010 | Sony KDS-50A2000 50" HDTV
Goodman furnace model#GCH90904CXAB the red light
Apr 25, 2010 | Goodman Heating & Cooling
Jul 20, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
53 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
