Question about AT&T 2256 Cordless Phone
"searching" message even when handset on the base
New phone. trying to set up and do the phone book. thought I would have to do the phone book after the initial battery charge, but still can't get phone book on the "sel" menu. handset still says searching even 'tho battery should be charged. red charge light has been on all night, maybe 11 hours by now. no dial tone even 'tho another phone plugged into the same line is fine.
  • bwv565 Jan 31, 2008
    i have the same problem (on a different AT&T model though). Sometimes while on a call, it can even disconnect the call and say "searching..." and finally after I hit the End button several times it'll go back to saying AT&T. I've had the phone for about 3 years, and usually let the charge run down before charging it again (my understanding of the best way to charge the battery), so it's not constantly in the cradle, but it does get a LOT of use. Sometimes the battery drains itself within 12 hours or so (I'm on conference calls all the time). This has just started happening to me in the past 3 or 4 months, and I'm wondering if it is a sign to go buy a new phone. Yuck.
  • Anonymous Mar 29, 2014
    The lights are on the base unit but the handsets say out of range or no base power, no dial tone.
  • 513 Answers
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Posted on Jun 05, 2006
SOURCE:
Put a new battery in my phone, now it gives me an out of rane message. how do I fix this?
I don't know what model it is but try these:
1. Check the main base is powered up!
2.Take out the battery again and edit a few mins and return it. Place the handset on the base. Now try.
3. If that didn't work you are probably going to to reassign the handset to the base. Check your manual on how to do that.
Nov 05, 2014 | Uniden Cordless Phone
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Dec 11, 2011 | Uniden DECT 6.0 Cordless Phone
I need the base id for a vtech house phone model number 6772
It sounds like you are trying to register the handset(s) to the base. Once the handset is charged, if you see 'Searching for Base' on the display,(The bold is for your question specifically but I thought you may like all of the information for getting a phone hooked up) ON the Base unit press MENU, scroll down to Display Base ID, press OK, and the Base ID code will display. If NEW appears in your handset display, press the soft key under it and enter the base ID code you found in the base display. If 'New' does not appear on your handset, press MENU and then scroll down to REGISTER. Press OK and then enter the base ID code. If the handset is already registered, please deregister all then register again. To deregister a handset which is registered to the base model 20-2431, Using the soft keys on the base, press the 'MENU', then press the down arrow once until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 6 times, until 'DEREGISTER ALL' is highlighted. Press 'SET' . If your handset is registered to the base model 20-2481, Using the soft keys on the base, press the 'MENU', then press the down arrow twice until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 7 times, until 'DEREGISTER ALL' is highlighted. Press 'SET'.
Benjamin
Jul 11, 2009 | Lands Phones
GE DECT 6.0 Model 28111EE2 is not working, registration failed message
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
Aug 26, 2008 | Uniden Cordless Phone
I have a binatone g11 cordless phone. I cannot make a call as the handsets keep telling me searching or out of area. Even when i place the phone on the base, it still keep giving me the same message.
Try taking the batteries out of the handset and unplugging the master base set. Leave for 15 minutes and then have a try. This often reprogrammes some handsets to the default mode.
Aug 24, 2008 | Lands Phones
Problems with C110 & A110 Vtech Mirage Dect Home phones
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
Jun 21, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
May 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
Panasonic cordless phone with answering machine model number Kx-TG2632 2.4 gigga range I miss place the book and I need help to adjust the volumn thank-you
The message on crystal reads"no link to base. Move closer to base, try again". I put in a new battery in each phone and not sure if they are charging. i keep getting the same message. What is the problem and how do I solve it?
Thanks
Dec 02, 2007 | Panasonic KX-TG2632W Phone
Handset flashes "searching" and has stopped working
Did you already try cleaning the connections on the phone and the base with alcohol on a Q-tip? Make sure the connections on the phone are touching the base propely.
Jul 19, 2007 | Siemens Gigaset 4210 Cordless Phone
Searching for base
My long-term experience with these phones is that occasionally, they get themselves into some kind of weird state: this is usually indicated by the flashing "searching" message.
In all cases it's been cured by unplugging the power supply AND the phone-line (both simultaneously) from the base, waiting a few seconds, then re-connecting. Normally this sorts things out, but will require you to re-set time& date (the base can sometimes still derive power from the incoming 50v line). Batteries out of handsets is a last (addtional) resort. I've very rarely had to re-register.
Jan 27, 2007 | Vtech i5871 Cordless Phone
AT&T 2256 Cordless Phone Logo
296 people viewed this question
Top AT&T Lands Phones Experts
Marvin
Marvin
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
