Question about HP Office Equipment & Supplies
I cannot clear the check print cartridge light. I've removed and reinserted the cartridges, turned off and on the printer and readjusted the paper.
    Sergeant:
  • 352 Answers
Hi dimy, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Posted on Oct 17, 2008
It won't print and the light keeps flashing. I lost the instructions!
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Feb 13, 2012 | Lexmark X1240 All-In-One InkJet Printer
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
Is only blinking and not printing when i try to print the usb conect successfuly to the compter but the printer is not printing the light is only blinking
The blinking light could indicate either a paper jam, communication problem between one of your cartridges and the printer or a short in one of your cartridges. Please follow the steps below to identify and fix the problem:
  5. Unplug and re-plug the printer into the power source to reset it.
  10. Load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 11, 2011 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1270. The paper goes to right and can not feed to print.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
The paper always jams when I want to print. It grabs the right side of the paper and scrunches the left side. It is a lexmark x5150 I have tried different paper and nothing works.
Jul 06, 2011 | Lexmark X5150 All-In-One InkJet Printer
Green power light is flashing for no apparent reason
Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Jan 02, 2010 | HP DeskJet 3940 InkJet Photo Printer
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
There is a paper jam Follow each of these steps until the problem is resolved:
  2. Press the Power button once. Wait a moment for the paper jam to clear.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Cause
Cause
Cause
Cause
Cause
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
HP DESKJET 3820 GREEN LIGHT FLASHING, WILL NOT PRINT.
Issue
Solution
Close the cover.
Issue
Solution
Issue
Solution
Issue
Solution
Issue
Solution
Issue
Solution
Cyber kaka
Dec 08, 2008 | Office Equipment & Supplies
23 people viewed this question
Seeker5211
Seeker5211
