Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
Accessing Service Menu for WS 65315 to change picture size
I need to fine tune the picture size for my WS 65315 and it seems the only way to actually do that is through a Service Menu which our local TV repairman wants to charge me $130 for them to come and access that menu to fix for me.
How about giving the consumer the same menu options a service department gets???
Please let me know if you get the service menu access code for this model.
    Top Expert:
  • Mitsubishi Master
  • 76,069 Answers
4 Suggested Answers
SOURCE:
MikeNJ1964
  • 398 Answers
SOURCE: Accessing Service menu to fix convergence
How far off are the colors misaligned such that you need to enter the service mode to fox them? If one or more of your colors has taken a dramatic shift in position, especially on any edge, then do not attempt to correct through the menu. If one of your convergence IC's has failed then the colors will not align on the screen. If you try to correct this in the menu, you will only be screwing up all the settings and making the set worse. When the IC is replaced with a new one your colors will still be way off, not because the new IC is not working, but because now the menu settings are too far off. I have been to many houses and spent 45 minutes replacing a burned out convergence IC followed by more than an hour realigning everything the customer messed up.
Posted on Aug 18, 2007
  • 1153 Answers
SOURCE: ws-65315 won't turn on
Need to know more, 1-2 is no error code, you say will not turn on, do it has led light on or do you hear sound in set like high voltage? Any lights blinking? Or just completely dead, like fuse blown?
Posted on Mar 24, 2008
  • 927 Answers
SOURCE: tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
Posted on Sep 01, 2008
65315 service menu
Two model numbers indicated here, if WS-65315 WHICH of the 3 hidden menus do you want?
May 31, 2012 | Mitsubishi VS-60611 60" Rear Projection...
Adjusting screen size
there should be a menu function on the tv remote push that to bring you to options and scroll around for picture
May 31, 2012 | Mitsubishi WS-65315 65" Rear Projection...
Problem with Mitsubishi WS-65315 65 in picture simply off the screen. too big for the screen so u cant see 15% of all picture. on any input source like cable, dvd, components.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Distorted picture on a mitsubishi ws-55613 tv
Their is no more you can do.
Seen this before.
You need a professional.
Stop using the TV until it is repaired.
Continue to use the TV and your problems WILL multiply.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Tv screen is scratched
I think This Company can help you to get new screen for your Mitsubishi TV.
Sep 30, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Green light doesnot turn off on Mitsubish WS-65315
Just go to menu... then ..setup... then... timer ..and turn it off...... the blinking light goes away
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Ws-65315 won't turn on
Mar 24, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
