Question about HP Office Equipment & Supplies
I continually get a "scanner failure" message on my display. Obviously, turning off and restarting the machine does nothing (as if this were ever any kind of solution), in fact, replacing the mother board in the machine did nothing... same message, same problem, same issue.... $ and time down the drain replacing the board. Borderline on being more practical to toss the POS out in the trash. Is there a quick, inexpensinve fix??
    Genius:
  • 2,120 Answers
Known issue by HP. Uneconomical to repair.
Posted on Oct 18, 2008
Got ink system failure code # 0xc18a0501 on HP Photosmart C7280 a-i-o and no amoun of shutting down and restarting will help. What can I do?
  1. Press and hold the "*" key.
  2. Press the "#" key and release both keys.
  3. Display should say "Enter Special Key Combo"
  4. Press and release in sequence the "1", "2" and "3" buttons. The screen will say "support"
  5. Press and release the right arrow button until the display says "System Configuration Menu".
  6. Press and release the "OK" button.
  7. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
  8. Press and release the "OK" button.
  9. Display should say "Hardware failure status: Clear. Press OK to clear".
  10. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
  11. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
  1. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  2. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  3. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
If it did not print out a diagnostic page:
  1. Is the error message still being displayed on the printer?
  2. Print a self test page to check the functionality of the printer.
  3. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
May 04, 2011 | Computers & Internet
Tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
on Jul 15, 2011 | Office Equipment & Supplies
Tip
HP Photosmart C6180 Ink System Failure
<br /> Hi,<br /> <br /> <br /> Please perform the following steps and let me know the message that will be displayed on the printer.<br /> Press and hold the "*" key. <br /> Press the "#" key and release both keys. <br /> Display should say "Enter Special Key Combo" <br /> Press and release in sequence the "1", "2" and "3" buttons.<br /> Press and release the right arrow button until the display says "System Configuration Menu".<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status: Clear. Press OK to clear".<br /> Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br /> Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.<br /> Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br /> Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer<br /> Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.<br /> <br /> If I could be of further assistance, let me know. <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
After I replaced toner, it continues to process "check toner". And now it says "toner is low" with the new cartridge intstalled.
Try turning it off and unplugging the fax machine. If you are receiving this error message on your pc, then it should be unplugged and restarted too.
May 03, 2011 | Office Equipment & Supplies
After installing the scanner I get a message that says "failure in initialization of scanner. Scanner is ofline or scanner power is off." I have checked all of the cables and the scanner is...
first most computers are plug and play, if yours is not then you need to load the software that came with the scanner, only then will the computer see the scanner
Mar 31, 2011 | Fujitsu fi-5120C
THERE'S GOT TO BE A SOLUTION TO MY LAPTOP PROBLEM,I KEEP GETTING THIS MESSAGE, "THE COMPUTER RESTARTED UNEXPECTEDLY OR AN UNEXPECTED ERROR. WINDOWS INSTALLATION CANNOT PROCEED TO INSTALL WINDOWS,...
The problem is caused by a damaged Windows installation CD.
There are some files that cannot be read from CD, so Windows gets stuck.
It tries to restart to continue with installation, and keeps doing this on an endless loop.
Solution:
Get a goos Windows Installation CD and start from scratch, (format and load the new copy of Windows)
Don't forget to rate this answer if it helps.
Jan 27, 2011 | Everex StepNote VA4300M Notebook PC
My Hp Laserjet M1120 MFP showing message "Scanner Error 6"
switch off the printer, then remove all cables connecting to the printer but just the power cable.
-then press and hold the *(start/symoble) and 5 button togather and turn on the printer.
-continue holding the button till you see "perment storage init" displayed and releas the button.
-then at a given point of time the printer will ask you to change laguage,time,date etc.
if this does not sort the issue service is required
this is work on 3055
so i think this work on your printer
Jan 04, 2011 | HP LaserJet M1120 MFP All-In-One Printer
The LCD screen keep displaying "Printing" but
I have seen this so many times I thought I would post an answer on this so you can repair your Brother MFC series machine that says printing and will not function. Using this procedure will save you from having to call out a service technician. Any time your machine says "printing" and will not do anything simply turn off the power. Now hold down the red clear/stop button WHILE turning the power back on. Continue holding the clear key for a few seconds then release. Your "printing" message should be gone and your machine should be back at the ready screen.
Good Luck and Thank You for using Fixya!
WheatlandServices
Dec 16, 2010 | Brother MFC-8220 Fax
HOW DO YOU RESET THE ERROR MESSAGE 0xc18a0207 on an HP 6100 series all in one ?
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
1. Press and release the “OK” button.
2. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
3. Press and release the “OK” button.
4. Display should say “Hardware failure status: Clear. Press OK to clear”.
5. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
6. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
7. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
8. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
9. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
10. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
11. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
If the error is still there, or reoccurs replace the unit
Jul 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
Scanner Failure
Have a look at this link:
http://forums1.itrc.hp.com/service/forums/questionanswer.do?threadId=989862&admit=-682735245+1194898272458+28353475
It's a bit techy but you can at least start there.
Mike
Nov 12, 2007 | HP PSC 750 All-In-One InkJet Printer
119 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
