Question about KitchenAid KWCU265HSS Kitchen Hood
Fan not working
The fan on the hood stopped working (i.e., nothing happens when I turn it on).
From this wiring diagram:, you can see that the hood has two circuit boards. One for slided switches and speed control (Part Number: AP3133509 made by WHIRLPOOL), and one for motor control (Part Number: AP3105889 made by WHIRLPOOL ).
My best guess was that the motor control board went bad, so I ordered a new motor control board to replace it. You will see five wires coming out of the speed control portion of the first board. The white wire goes directly to the fan motor, but the other four (blue, orange, black, and black), go to the motor-control board which also has four wires of the same colors.
OK. Blue to blue, orange to orange. No problem. But what about the two black wires coming from the speed controller and going to the two black wires on the motor-control board? Does it matter how these are connected? I figured if it mattered, they would also be color coded, so I just connected black to black, black to black (random order). When I turned on the fan, it blew out my new motor-control board.
I have a new motor-control board. I was going to try reversing the two black wire connections, but don't want to blow out another board. So, my question is, do you think it is important to match a specific black wire on the motor-control board to a specific black wire coming from the speed controller? It seems strange to me that it would work this way, as these wires snake around through the hood, and it virtually impossible to tell which is which when when they reach the motor-control board. I don't know how they would be been matched during original assembly. But I can't think of any other problem.
By the way, I was able to by-pass the motor-control board and run the fan directly, so I don't think the problem is with the fan motor. I have also replaced the control board used for the slider switches and speed control, so the problem is not there either.
Thought welcome. Thanks.
SOURCE: Mixer works at high speed only
You might have someone repair it for you; here is a place that charges a flat fee of $69.95 and thats including the return shipping. Check 'em out: The speed controller board sounds like the right direction but it hard to know if that is the issue until you install a new part. This is a known issue as far as I have heard around the internet. You might give KA a call and see if they can help; all they can say is no. I have heard they revised the part to fix the problem; my brother had a couple of boards replaced on his pro model and now it seems fine. Good luck!
Posted on Aug 19, 2007
  • 2651 Answers
SOURCE: wiring hookup for a replacement part
hopefull yyou havent disconnect old switch yet. whirpool and kit aid are same Co. same parts used. assuming the correct part was sent for the corrrect burner. diffrerent element will require different rated swties(ie. small , large, dual and so forth.), the indivudal switches are labeled, on the swithc itself ( L1,L2,H1 H2, P1 andso forth, so although the switches looke differnet they should stil have the same lettered terminal to plug into .
Posted on Mar 16, 2008
  • 171 Answers
SOURCE: light and blower speeds malfunctioning
Hi mutt750,
I'm Harvey the Master Plumber.
I agree. It sounds like your neighbor is doing well. I would replace the control board too. Sounds like a nice guy. Time to invite him over for a bbq?
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: need wiring solution for replacement part
Ok....Just replaced the Left Front "dual burner" switch on my Kitchenaid Supurba.
Original switch symptom:
Burner was stuck on all the time. We had to switch the circuit off in the main breaker box in the basement.
New switch problem:
The new replacement switch did not work properly. The element would come on and would never cycle on and off. Thus, the net result was if you turn the burner on, it was on "high". It didn't matter where put the heat setting at...It's on high for both the inner element and the larger outer element.
I ended up taking the old switch apart and found that one of the contacts was mis-aligned and wedged itself in the "closed" position. I un-wedged the mis-aligned contact and bent it back into alignment. I took out the new switch and put the old one back in. It works perfectly.
Meanwhile, I had to figure out why the new switch was not working. The new switch comes with re-wiring instructions because it is not an exact replacement as the old switch. There is a chart that tells you what wires go to which prongs on the new switch. The new switch also includes a "jumper wire" that must be installed. Here's where I went wrong. The instructions say to jump S1 to P1 (which I did). But, I did not route it exactly as the picture shows and the brass crimp end actually hits against another unused connector. So be careful when routing the jumper wire.
Old Switch Number: 9751758
New Switch Number: 8203536 (Made by FSP Appliance Care Products - A Whirlpool Corporation)
Now for the wiring:
Description Wire Color Old Switch New Switch
& designation Terminal # Terminal #
L1 Black (RL1) 2 P1
H1 Red 3 4
H2 Orange (LFA) 4 4A
P Dark Red 5 S2
N or L2b Brown (LFN) N 2
N or L2b Red (RL2) N P2
On the new switch, use the supplied jumper wire to jump S1 to P1 as instructed.
Yes, on the old switch, 2 wires connect to a common connector (the Brown LFN & Red RL2).
Unfortunatley, I did not document the red wire (LF3)...Sorry....
Hope this helps.....
Posted on Apr 05, 2009
  • 57 Answers
SOURCE: Mixer won't start
I have a PDF file entitled "kitchenaid service manual" that I could send you that I got online and can't remember where. If so my email address is Send me an email and I'll reply with the PDF enclosed. Otherwise try a google search of the above and you might be able to find it.
It's looks old but covers all the essentials including a wiring diagram
Posted on May 07, 2009
My 2003 ford escape my cooling fan is coming on as soon as I turn my ignition on cold or hot.
One of the relays may have fused. Open the hood, look in the relay box. There are three fan relays. Turn the key on and pull out the relays one at a time to see if the fan stops. If it does, press the relay back it--does it click? If it doesn't click, replace it. If it does, the problem is the wiring--relay turn on wire from the pcm is grounded.
If the fan does not stop with the relays out, someone has messed with the wiring. See diagram at the link below.
Aug 13, 2017 | Ford Cars & Trucks
PK2229 blower stop working
Light and fan are two separate functions in your hood. The fan gets very greasy from the cooking. The grease doesn't act as a lubricant but as dirt. Remove the fan from the unit and check to see if the shaft is wiggling,or if it is seized. At this point you may need to replace motor. If it turns somewhat put a few drops of oil at the shaft, both ends if possible, and spin the fan by hand until it's loose. Replace back into hood and see what happens. Many times the bearings in these fans go dry and will not spin. GOOD LUCK FRIEND.
Jan 18, 2015 | Kitchen Ranges
How to check if cooling fan is working properly
Start the engine with hood up. Wait for it to reach operating temperature. When it does, fan should cycle on for a few seconds, then off. If it doesn't come on, turn car off and make sure fan is free spinning-no obstructions. Be careful, if engine is warm, fan can come on and start running. If fan is free wheeling, jumper it from battery to fan connector to check fan motor. If motor works when given battery voltage but still won't come on as it should (usually the engine has to be quite warm to turn on the fan-as in stop and go traffic, or long idle times), you will have to check wiring at the fan relay, check if temperature switch to turn fan on is working properly, check if computer is signaling fan to turn on at the relay. You will probably need a wiring diagram if you don't find the problem as a bad fan motor or bad relay.
May 25, 2013 | 1995 Oldsmobile Achieva
Just quit. Worked fine one day. Next day went to turn it on and nothing happened. Fan is little over a year old.
Control switch, circuit breaker, or loose wire are main suspect.
Rarely does a motor just stop working.
Check circuit breaker.
Open control switch and test for power and check for loose connections.
Install ordinary on-off switch and see if function resumes.
Check wire connections at fan.
Jul 11, 2011 | Air King 9166 20" Whole-House Window Fan
I have a 1994 toyota camry and both fans have stop running in front of the radiator. I changed the thermostat, fan cooling sensor plug and nothing happened. I went into the fuse and relay box under the...
Sounds like you have corrosion at the fuse connection, try taking a small wire item like an unfloded small paper clip to clean that connector in the fuse box and replace that fuse, be cafeful to disconnect the negitive [ - ] battery post before you try this.
May 06, 2011 | 1994 Toyota Camry
Heater fan does not work and the fuses are ok where is the relay
the relay should be located in the fuse/relay centre under the hood. best bet would be to start the truck and turn the fan on high, then wiggle the wires attached to the fan motor. if still nothing happens then give the fan motor a tap with the end of a screwdriver. if the fan begins to work after hitting it u will need to replace it
Jan 25, 2010 | 1995 Chevrolet Blazer
2001 honda Civic LX
CLICK HERE for your Blower Motor Circuit Diagram.
There are 2 fuses for your blower.
One Hot all times ( #35 under Hood 40A)
One Switched power (under dash fuse #9 7.5A)
If BOTH fuses check out good, there is a relay under the dash.
(Yellow with black stripe ) and (Black) wires coming out of it.
With the ignition on, and blower set on 1, verify power at Yellow with black wire at the blower.
If there is power, your blower moter has failed.
If you need more help, let me know.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 28, 2009 | 2001 Honda Civic
Fan and light does not turn on .
my zephyr typhoon stopped working. Neither light not the fan come up. I am sure there is power going into the unit. I turned on the light one day , the light cam on and suddenly went away. From then even the fan stopped working. any information on what happened is appreciated. Thanks
Jan 22, 2009 | Zephyr Typhoon AK2100 Kitchen Hood
94 gms safari van heater blower not working
This van has a resistor under hood for the blower motor and is the blower motor getting power to it
Jan 17, 2009 | 1989 GMC Safari
Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
Nov 04, 2007 | Ovens
KitchenAid KWCU265HSS Kitchen Hood Logo
65 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
