There could be several reasons why your unit is "overheating". Is the motor tripping the circuit breaker ? Is it the motor or the compressor that is overheating? I need more description of the problem. 3 phase motors do not have capacitors. Is the compressor turning the correct direction? Is the supply voltage correct? Is the power cable the correct size? Do you have the correct type and quantity of oil in the compressor?
SOURCE: I need to build a single phase to three phase
You will need a rotary converter for this, or a single phase motor. A three phase motor absolutely cannot be made to run on single phase otherwise.
SOURCE: binks model 33-1031 air compressor 3 hp 3 phase
G'day, As a general rule, for each one horsepower of motor size you get on average 4 cubic feet per minute. So 3hp motor = about 12-14 cfm.
Hope this was helpfull.
Regards Andrew Porrelli
