New installed W.Bosch Greenstar 30CDi with DT20RF programmer. Have been getting intermittent cut out of heating when in progress as indicated on the programmer display by flashing green heating led and flashing CH & RF receiving icon on lcd disply. The heating ceases and resumes eventually on its own accord.The thermostat is still requiring heating according to its display. The thermostat batteries are fine ,there is no error messages on thermostat. Any ideas?
  • 3 more comments
  • fixya346 Nov 19, 2008
    My Worcester Bosch Greenstar 30CDi with DT20RF programmer was installed in April and has same symptoms except the only thing flashing is RF receiving icon on lcd disply.
  • lambertsj Dec 12, 2008
    my dt20rf has just started doing the same thing (installed april) i have noidea whats causing it can the radio frequency be interfered with by anything?
  • philjames Dec 20, 2008
    Unit was installed earlier this week. Exactly the same problem is occurring. Heating comes on and off at apparently random times.
  • tez100 Dec 22, 2008
    Same as other posts...unit has been installed about 10 months...replaced batteries...cant setup RF link.
  • xeejay Mar 14, 2009
    The Heating does not function until the OK button is pressed and then it will not allow selection of timer mode for about ten to twenty minutes, it eventually reverts to timer. The antenna is flashing during this time, could it be interference form our computer network modem which is quite close by?
One of my customers had the same fault recently. We tryed to reset the radio connection but, the appliance still did not respond.
The receiver was disconnected for the evening to prove boiler and system functionality which was ok.
Next day we installed new receiver & followed set up. customer has had no symptoms for 2 mnths.
Hope this helps.
Posted on Apr 21, 2009
How do you work the heating on a Worcester bosch 35cdi boiler
search for worcester bosch 35 cdi manual choose Greenstar CDI & download the pdf instructions
Dec 31, 2014 | Bosch Water Heaters
Bosch SGS6302 Dishwasher failing to complete cycle
Does it heat properly? Was that the cause of the power failure?
Mar 17, 2014 | Bosch Dishwashers
Greenstar 30cdi no hot water
It is the shower head or plumbing that has a built in mixer or reducer.
Dec 09, 2013 | Stiebel Eltron CK20E Electric Tankless...
Greenstar 30cdi hot water issue
The problem is not the water heater. The shower has a mixer or a limiter built into the plumbing so that the water wont get hot. It is a safety feature to prevent burns and protect children from scalding.
Dec 09, 2013 | Water Heaters
Greenstar 30CDi conventional condensing boiler and the temperature is fluctuating rapidly and repeatedly between 37 and 63 degrees. It is set on 4 so just above 60 sounds correct according to manual....
It sounds like you have air in the system, Turn Boiler Off keep pump running and try to find a spot where you can bleed the air out.
If you dont have an automatic water fill installed then
you will have to add water by hand
Feb 14, 2010 | Heating & Cooling
Bosch exxcel programme runs until 1 min left and won't finish
This is a fault code which indicates it has not heated through the programme
Dec 13, 2008 | Bosch 24 in. SGS43C12 Classixx...
Heating & Cooling Logo
1,366 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
