You have not indicated if the blackberry will run when absent a battery it is plugged into a charger. If it does, that suggests a battery problem and you simply need to replace the battery. If a red light blinks on the blackberry when you try the above, try a hard reset. But before that, try the below.
Push and hold the call button and alternate with the end call button until the hourglass shows. Allow some time to boot up.
You can reset blackberry phones from network restriction using unlock codes, you can purchase such codes from any vendors online like http://www.unbblock.com/blackberry/rs18wp8/
Well you can again upgrade the 9700 software from here
http://senseapplied.com/index.php/upgrading-blackberry-9700-and-9300-to-firmware-6-0-0-448/
If you like the solution do give us all thumbs up
Farhan
With any JVM Error you are going to need to reload the operating system to your device, this process is slightly different with each carrier, so it is important to contact them during the process, first (if you have not done so already) Download and install the Blackberry Desktop Manager to your computer, The Desktop manager can be obtained from blackberry.com once installed you will need to download and install the most up to date software from your carriers website,then follow the instructions to install the software to your phone, now unfortunatly your going to lose any information you have not backed up to your computer
When adding, deleting, or updating applications on your BlackBerry smartphone, you receive the following error message: Device error 400 OR
your BlackBerry device resets itself and stops responding.
CAUSE
An unspecified error has occurred with an application on your Blackberry smartphone.
RESOLUTION NOTE:The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
Disconnect your Blackberry smartphone from your computer.
Open BlackBerry Desktop Manager.
Open BlackBerry Application Loader.
Reset your Blackberry smartphone.
When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
Click Next.
On the following screen you will see either USB:Unknown or USB:; click Next.
Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
you needto reinstall the blackberry software on your phone using the blackberry desktop. Download your corresponding software (t-mo=8120, AT&T=8100) and install it on your computer. then using the Blackberry desktop, under install apps, reinstall your software into your phone
