Kenmore Elite 45986 Front Load Washer
Problem for Kenmore Elite 45986 Front Load Washer
Water overflowing from drain pipe
By yes2life on Jun 03, 2006
The drain hose is properly inserted into the drain pipe. After over a year of use with no problems, the water overflows out of the drain pipe back into the laundry room. The plumber has been out twice and snaked the drain through the drain and from the roof. He ran the garden hose through the pipe for ten minutes with no back up. There is also a sink and a toilet on the same line and they work fine. I use High Efficiency liquid laundry soap and I don't use more than the recommended amount. When I run the drain hose into the sink instead of into the pipe, I can see that for a short period there is a lot of water that comes out and fills the sink up 4 or 5 inches before it drains. Could it be releasing too much water at once for the drain pipe to handle?
I can't figure out the next step to this mystery!!!
Comments:
Jun 03, 2006
- Thank you or the comment about the sink drain. It does drain quickly in the sink (about 4-5 seconds). Are you saying that the garden hose pressure isn't as much as the draining from the washer?? The plumber thought the garden hose had more pressure. Hmmmmm.
Same Problem
Jun 02, 2008
-   Just moved into a used modular home and when the washer spins out the water, it drains fine for the first few seconds; then starts shooting out where the washer drain hose is connected into the standpipe. I can stop the spin cycle and let the pipe drain, then start it again, stop it, etc.-   Laulw
Dec 07, 2007
-   i've had my washer for 5 years with no problems. now when it drains it overflows out of the standpipe. ive checked my sewer line and it seems to be clear. it also does not do it every time-   4parfore
Best Solution
posted on Nov 10, 2007
Very Helpful)
sdanville
Rank: Apprentice
Rating: 100%, 1 votes
I had a stubborn clogged drain pipe. It took 4 times with a 3/8 " power snake until I stopped getting calls from the tenants. The chemicals I bought were no use.
Was this helpful?
Yes
No
Solution #2
posted on Jun 03, 2006
Very Helpful)
dovi
Rank: Guru  Kenmore Expert
Rating: 88%, 2515 votes
Your experiment to run the drain hose into the sink and the fact that water didn't drains immediately, shows that you have a blockage on your main drain line !!!!
The garden hose running through the pipe didn't raised up the problem because of water's pressure.
My recommendation - Buy an "open blockage" liquid (you can get it in all hardware stores) and use it following the instructions you have on the bottle.
Good luck !!
Was this helpful?
Yes
No
Solution #3
posted on Jul 28, 2008
Helpful)
jtate9
Rank: Guru
Rating: 90%, 53 votes
The problem with the new washing machines, is that they dump 20-22 gallons of water in 4-5 seconds. This amount is far more than the garden hose test will submit the drain to. Here are a number of solutions, I hope that one of these will help you.
#1 As mentioned above, you can restrict the flow of the drain pipe. I recommend a 3/4" x 6" brass nipple, or a 1/2" x 6" brass nipple, depending on your specific situation. The brass nipple will not corrode like a galvanized nipple.
#2 There is also a rubber cap that you attach to the drain pipe that fits around the drain hose tightly.
#3 Some situations might require that you have to raise your drain pipe. It is recommended that it be at least 36". This allows for gravity to assist the drain.
#4 Some situations will require that the drain pipe be increase in diameter. Older plumbing applications were installed using 1 1/2" piping. With the newer washing machine discharge volume, the 1 1/2" pipes will not support the discharge. Your drain line will need to be changed to 2". This option will be one of the more costly fixes, depending on the amount of line that needs to be changed.
#5 Some plumbing installations installed without a p-trap will need to be changed. The p-trap keeps sewer gas from coming back into the house. It also allows for a smooth transition into the drain line. Any restrictions in the drain line (i.e. ells, tees,) will cause the soap in the gray water to foam up which will cause the drain line to slowly back up.
I hope these solutinons help.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Jan 26, 2008
Helpful)
fixitmom1
Rank: Apprentice
Rating: 86%, 4 votes
I have the same problem with the washer drain overflowing as it drains the tub.  Have had a plumber run the snake, sewer and drain people come with the "big" snake to go from the house to where the city line connects, and the city out to check their side.  I am convinced that the problem lies in the amount of water being forced out of the tub and into the vertical pipe.  First, I think I will try to reduce the amount of water coming out of the washer.  If that does not work, then I will have to look into the possibility of getting a larger diameter vertical pipe,,,
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Jul 10, 2007
Helpful)
LarsTo
Rank: Apprentice
Rating: 85%, 2 votes
LarsTo here, I have exactly the same problem. We have not changed washing machines. We have not changed any plumbing. Frequently I find an overflow. I have stood and watched the complete cycle of the washing machine and noticed that the soap bubbles, aparently with water in the suds, comes right up the drain standpipe. I have done the drain cleaner thing, the hose thing, the drain in the sink thing, and only spent money and time. I have a friend who is a plumber and asked him about my problem. "Too much soap used in the load", he says. I look in the liquid soap cap and see lots of lines. I tell my wife what my friend the plumber says, and she replys; "I only used a little." Last evening it happened again, this time I look for answers on the internet. I tell my wife what others are saying and she says, "Well maybe I'm putting too many cloths in the machine". I get in deep trouble reminding her not to use as much soap as that new wasing machine that does 15 pair of jeans per load. I hope I can be teachable, maybe even a few others remain so.
Was this helpful?
Yes
No
Solution #6
posted on Jan 08, 2007
Helpful)
jctoad
Rank: Apprentice
Rating: 84%, 5 votes
I would say that the problem lies somewhere within the house plumbing. Finding it seems to be the problem.
The garden hose would have more pressure than the washer. However, the volume from the washer probably is greater than that of the hose. This is because the washer hose is greater in diameter than the garden hose allowing more flow at less pressure. So much flow in fact, the problem drain lines in the house can't handle it fast enough.
A work around could be to restrict the flow coming out of the the washer. You may be able to do this by clamping the end of the washer drain hose or clamping the hose in the middle somewhere. This will not hurt the pump, it will just take longer for the washer to pump out preventing a "flash flood" of your house plumbing and your floor.
Was this helpful?
Yes
No
Solution #7
posted on Feb 14, 2007
Somewhat Helpful)
here_to_help
Rank: Apprentice
Rating: 81%, 15 votes
If the water is backing up from the standpipe then you obviously have a problem. The most important thing is to properly diagnose the problem. There are many factors that come into play, however. Factor #1 - Is there a clog in the line? Run a water hose in the standpipe and see if it backs up. If so, the line needs to be cleaned out with a 3/8" drain cable. Then test the performance of the washing machine. Factor #2 - Did you recently get a new washing machine? The reason I ask is because newer washing machines have a higher output than those manufactured 10 or more years ago. If the washing machine is new, and it is backing up during the spin cycle, but the machine you just replaced was draining with no problem, or you have tested the line with a water hose, then the problem is the stand pipe. The STANDPIPE is the pipe the hose sits inside to drain. When the home was built, the standpipe was sized at 1 1/2 inches to handle the output of the washing machine. The pipe and it's trap are that size until they dump into a 2" drain line which runs into a 4" drain line. THE SOLUTION is to replace the 1 1/2 standpipe and trap with a 2" standpipe and trap. The larger pipe and trap will handle the higher output of the new washer allowing easier access to the 2" drain.
Was this helpful?
Yes
No
Solution #8
posted on Feb 28, 2008
Not Rated)
airtospare
Rank: Apprentice
Rating: 0%, 0 votes
I am having the same problem that most of you are suffering from also. I have just removed a lot of old pipes from a suite that was in the basement next to the laundry room, and after replacing the standpipe and drain line my machine now overflows out of the standpipe. I did not install a trap but have noticed that the drain line does not have a Y-Tee but a straight Tee. I think that the straight tee is not allowing the waste water to drain away fast enough. Any thoughts on this. Thanks, Bud
Was this helpful?
Yes
No
Solution #9
posted on Feb 19, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Has anyone suggested to reduce the water flow out of the Washer? Maybe installing a restriction in the drain hose will solve the problem. The Washer Machine doesn?t have to empty in 4 or 5 Seconds. The spin cycle lasts for 4 to 5 minutes.
My older model Maytag never had this problem in the 10 or 12 years we had it. As soon as we installed the new Maytag, I had to increase the height of the stand pipe, but even this didn?t correct the problem.
Solution #10
posted on Nov 30, 2006
Not Rated)
davegha
Rank: Apprentice
Rating: 0%, 0 votes
davegha indicated that his solution for
LAT3600A Top Load... Problem
is valid for all Kenmore Washing...
I have the same problem - exactly the same problem. Hose drains fine. I am wondering if you solved your problem? What did you do?
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite 45986 Front Load
Questions and Unsolved Problems for Kenmore Elite 45986 Front Load
Do you recommend Kenmore Elite 45986 Front Load Washer?
Answer
Answer
kenmore elite he3t, stopped on the rinse/spin cycle and just clicks
Answer
when i turn the washer on , and the water gets added water starts to flow from the bottom of the... (More)
Answer
iam replacing the switch and can not figure out how to remove the case.
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Las Vegas, NV
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
