After installing Windows 7, and putting back my backups the Computer screen turn Blue and asked something like Check Disk/ Disk Space while I have more than 400GB available. After restarting the PC it can not boot to HP Logo and keeps on Restarting...? So please I really need help here.. Kems.
Check the ram memory if it restarting in a loop ..when it gives memory blue screen is not referring on hard disk only ..it may be teh ram memory as well ..and if it had errors it is probably something wrong with the way you installed or the partitions you have ..You need a large C drive partition made for windows & ..at least 50 G and you need to format it when you install so that it is clean and functional ..If you installed over another OS..or not formatted it or it is too small ..even if you have space in other partitions this is not a solution ..You need to have space in C drive where the windows works ..
Other issues ... maybe is a file missing and does not let it boot or ..you made changes in BIOS .. for example if you installed the OS on a sata hdd ..and it was non raid ..and after that you defaulted the BIOS settings ..you may need to check the sata bus and see how it is set .. and probably need to reinstall the operation system ..If you want to use it with raid ..set it before installing ..and make a large C drive for it to work cause windows alone will have almost 20 g after first update .. Also download and put the raid or ahci driver on a usb stick in case it will ask it (will not see the hard disk on raid without driver ..even if the windows 7 usually it works cause it has the driver on install..)
So ..check BIOS .. and see if it loads teh operation system when you put the hard disk sata on non raid or on compatible or on native .. it may be presented differently but the idea is teh same to disable ahci or raid for the hard disk ..and save changes and exit ..After that may work ..Also remove and reinsert ram memory and see if there is something wrong with it..and the last action reinstall cause a file from the boot sequence may be lost and this is the cause for not starting .. it happens when you do not format teh disk and it has an error on it .. For the other drives and partition ..it may be enough to make a defragmentation ..for now if you have files on them and you install only the C drive ..
Let me know if you still have problems with t ..
SOURCE: When computer opens, incomplete Touchsmart windows appear
it mean your windows is corrupt just format & reinstall fresh copy of windows.
866-408-5408(Phone Support for Touchsmart)
It can be due to software as well as hardware issue. There will be an error code mentioned there in that blue screen. Best way to resolve it will be to take a backup of all the data and do a complete System Recovery using the Recovery Partion or Recovery Disk. Still if the problem remains then it is definetly a hardware issue where any one of the hardware part will have to be replaced.
Do reply with the results..........................................
