Question about Maytag Dryers
When starting, Maytag frontload dryer makes a clunking sound,then quiets down
Could the belt be going out?
  • 67 Answers
It is possible, although when my belt went out, it was a squealing sound. it is easy to access your belt. make sure power is off. most maytag dryers can be opened up from the front. first remove bottom panel, this will expose the screws needed to get to the front panel (the one that has the door in it). once this is off, you can inspect the belt with your hands and a flashlight. if you think it is bad, it is best to replace it, they are not that expensive when you but online. also, if you are replacing it, you should check all of the rollers that the drum rotates on. they should be able to spin very easily. if they do not, you might as well replace them also. i found that out the hard way. hope this helps!
Posted on Oct 17, 2008
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
Good luck.
Mar 02, 2011 | Maytag Dryers
Dryer has developed a noise (clunk) as it turns
the clunk is from a worn bearing on the belt tensioner that the drums belt goes through. If the bearing freezes up the rubber layered roller will get out of round and sound like a drummer beating on a drum
Feb 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Maytag LDG9334AAE Gas dryer making popping noise from vent
clean clean clean everything, dont let it go to much longer or you will have a fire, and dont ignore this or you regret it... then tell me if it makes the noise
May 07, 2009 | Maytag Dryers
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Clunking sound on dryer
Remove the front panel and check the blower wheel attached to the motor.
It may need replacing.
Possibly lint and debris blocking it.
Feb 21, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Noisy dryer
Don't turn the tub to much this may make the belt run off track . If the machine makes a rumble at the beginning and at the end or when u stop the machine and restart it it is probably the blower wheel,it is made of plastic ans wears out on the motor shaft.
Apr 05, 2007 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
105 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
