Question about Baby Gear
Convert Geneva Convertible Crib by Childesigns to toddler bed instructions
I need the instructions on how to convert this crib to a toddler bed.
  • Anonymous Oct 19, 2008
    I can't find any safety rails that will work on this once I convert it to a toddler bed.
SOURCE: converting crib into toddler bed
Call customer support @ 18002951980 and customer support can either email or fax instructions at no charge. I just did it and got the instructions myself. Or you can email me @ shannaboxley@yahoo.com and I'll foward the instructions to you.
Posted on Jun 20, 2008
SOURCE: Crib to toddler bed instructions
I need instructions to transform my mama and papas Aspen Cotbed into a bed! We have lost the instructions! Can u help?
Posted on Oct 17, 2008
SOURCE: Jardine Crib 4 in 1
step 1: detach the front panel (part j) from the front posts h(1) and h(2) using allen wrench
Step 2 if mattress support (part K) is not in the lowest position, unscrew mattress support bolts (Part d) from the post and move it to the lowest position
Step 3: Using the wrench provided, attach the guard rail (part f) using 4 bolts (part a) between the left and right front posts
Step 4: tighten all screws clockwise.
good luck
Posted on Oct 24, 2008
  • 5 Answers
SOURCE: Need instructions converting crib to toddler bed
I have all the instructions posted in an album on photobucket.com. In the site only search field (not the web search) type emilykenepp and change the search criteria from images to people. This should bring you to my profile- under my albums I have an album titled Graco Lauren Crib Assembly Instructions. Click on that and you should be good to go! Pages 10 and 11 are for the conversions. Also, for any further assistance, the customer service number for LaJobi (the people who actually manufacture the crib for Graco) is 1-888-266-2848 and for Graco it's 1-800-345-4109. Hope this helps!
Posted on May 07, 2009
  • 5 Answers
SOURCE: graco lauren crib conversion instructions
I have posted the instructions in an album on photobucket. I believe you can print them from there. To get to them, go to photobucket.com and in the website only search field (not the web search) type emilykenepp and change the search from images to people. It should bring up my profile and under albums I have an album called Graco Lauren Crib Assembly Instructions. Click on that and you're good to go! Pages 10 and 11 are for conversions. If you have any further need, the number for LaJobi is 1-888-266-2848 and the number for Graco is 1-800-345-4109.
I need to convert our sorelle tuscany convertible crib to a toddler bed and lost the instructions. how can i get a set of instructions?
http://www.sorellefurniture.com/instructions.php
Not sure what model yours is, but that's their site for instructions.
Mar 14, 2011 | Sorelle Tuscany 1050 Crib
Need instructions ofr converting crib to a toddler bed.
This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
www.milliondollarbaby.com/help.milliondollarbaby.com/
*For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
*For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
For cribs with Safety Glide nylon(rodless) hardware
Sleigh Convertible 3001 Crib
Sleigh Convertible 3091 Crib - Safety Glide
Jenny Lind Crib
Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
Ashley/Alexandria Crib (3-piece headboard) +Day bed info
Lauren Crib ) +Day bed info
Emily Crib (One piece headboard) ) +Day bed info
Emily Crib (Four-piece headboard) ) +Day bed info
Mini Emily Crib
Anastasia Crib
Bridget Crib
Valerie Crib ) +Day bed info
Bailey Crib ) +Day bed info
Ellie Crib Day bed and full bed info
Kalani Crib Day bed and full bed info
Bordeaux Crib Day bed and full bed info
Annabelle Mini Crib
Italian Cribs-Metal Barrel Nut
Italian Cribs-Nylon Nut
Canopy cribs with snap-in spring hanger hardware
Canopy cribs with metal bolt-in hardware
May 16, 2009 | Bassett New Haven 3 N 1 Crib
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Need instructions on how to convert my aspen simplicity crib into a toddler bed?
i think this is the same crib that i have. I remove the front rail that slides up and down, then i removed the plastic contraptions that allow it to slid up and down on. I then attached the bed frame on the lowest setting, by first fastening the two back ends first. Then I attached the toddler rails to the bottom of the bed frame and then once they where on I attached the bed frame to the crib with the rails and the brackets for the bed frame pressed together. I hope i explained it so that i makes sense.
Mar 14, 2009 | Simplicity for Children Aspen 3 in 1...
Convertible crib directions
there should be a sticker somewhere on the furniture that tells you exactly which set you have. from there you can either email them or call and they will send or fax the instructions. hope that helps.
Aug 03, 2008 | Baby Gear
Change crib into toddler bed
You may find the following link helpful. It contains video instruction on how to set up the different configurations. Hope this help and let us know if you need further help.
Apr 29, 2008 | Simplicity for Children 4-in-1 Convertible...
How to convert crib to bed
I have the opposite problem - I can put it together as a toddler bed. The trick with that is that you put one of the long screws through both the hole at the SHORT end of the toddler bed side AND the metal flange from the springs into that end of the crib. The other long screw goes through the raised end of the toddler side into the end of the crib - where the child's head would be.
Is there supposed to be a plastic piece at the top of both ends of the crib on the side that does NOT go up and down? I can't seem to figure out how to put the crib side on.
Nov 03, 2007 | Childesigns Bellmont Crib
Baby Gear Logo
270 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
