Question about Dell Latitude D620 Notebook
Dell Latitude D620 Laptop Screen Resoltuion Stuck at 800 x 600
Somehow the screen resolution is 'stuck' at 800 x 600. I go into the Control Panel -> Display -> Settings and change the resolution slider to 1280 x 800, hit Apply, but when the laptop reboots the screen resolution is back to 800 x 600. How do you get the change to 'stick'?
  • rhowe493 Oct 17, 2008
    Okay....for us novices....where would one find the video drivers at the Dell website?
    Okay, I managed to find the solution, but it doesn't make complete sense why this worked, but anyway:
    I went to Display Properties --> Settings --> Advanced --> General --> and changed "After I change display settings" to Apply the new display settings without restarting....
    Once I did this, the changes stuck, even after a re-start.
    Thanks!
    Brigadier General:
  • 6,966 Answers
Initially, pls check if the Display Drivers are installed by having a look inside Device Manager. There should not be any yellow or red marks particularly on VGA Controller or Display. Additionally, pls check the laptop's Display Properties (Control Panel) and verify in the Settings tab, Advanced button, that the monitor selected is an LCD/TFT.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 17, 2008
    Brigadier General:
  • 3,614 Answers
You must install the video driver of your laptop. if you have a devic driver on the cd for your laptop, that would help..
  • Dell Master
  • 19,396 Answers
That usually means that you have to reinstall the video drivers.
  • Ginko
    Ginko Oct 17, 2008
    There are two versions of video adapter for the Dell D620, it mounts either an NVidia or an Intel video adapter.
    Download drivers from here.
    If you do not know what video adapter you have, then download both, if the driver is wrong, it will just stay as it is now.
    If no driver works, then the Video adapter is faulty, on a Dell D620 that means that you have to replace the mainboard, but that is an unlikely event.
    Reinstall video driver, that should fix the problem, try both.
I have a dell latitude D620 that the screen look blurred, i change the resolution to the highest but still blurred.
It is unfortunate that the LCD screen has blurred. There is a possibility that the LCD screen has failed. You may want to use the below link and performing an LCD BIST:
http://dell.to/1irqbYp
Also try connecting a known good external monitor and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jul 01, 2014 | Dell Latitude D620 Laptop (Latitude-C620)...
How do i put the sound back on my computer?
What is the OS on your computer?
What excatly did your wife delete?
Jan 08, 2013 | Dell Latitude D620 Laptop (Latitude-C620)...
I've connected by Dell Latitude D620 VGA to my HDMI LCD TV but there nothing displaying on the TV
Try lowering screen resolution on TV. There is a chance your video card can't handle HD like 1080 dpi or higher. Plus make sure TV input is set to VGA.
Aug 31, 2012 | Dell Latitude D620 (D620-rfb1.6) PC...
White spots..
Dell Latitude D620 Laptop (Latitude-C620) PC Notebook
take alook there and see if you can tell what to do.
Then I often find that is good to click on START-control panel once there click on display. There you can control your sisplaay and hopefully get rid of the white spots.
all the best
kollagunn
Feb 21, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
Battery on pc charging slow
Click on the battery icon on the bottom right of your screen and make sure your computer is in Battery Saver mode. This should help it charge faster. In addition, closing any open programs or rebooting should help close any tasks that got stuck open and are draining CPU power.
Dec 26, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
When i turn my computer dell latitude d620 on it comes to the dell screen then the windows xp screen and then it goes black with nothing more than the mouse. what could be the problem?
This sounds like a video issue. Try starting the system into safe mode (after the dell screen, tap F8 to get the startup menu and then select safe mode) When in safe mode, go to the control panel and remove the display adapter driver from the device manager under System > hardware tab. Try booting into normal mode windows- you should be able to get into windows at that point. Download and reinstall the graphics driver from support.dell.com. If the issue reoccurs after you've reinstalled the graphics driver, it means that the video card on your system has gone out. At that point, contact Dell technical support if you are in warranty to get service- if not, try pricing the replacement video card from Ebay or Dell parts service.
Oct 05, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
How to remove Dell Latitude D620 BIOS Password.
send me the service tag wich u can see on the bottom cover or trun on laptop u will see on screen hash code like this XXXXXXX-595B or D35b or 2A7B send me complete .ill send u password .
Jul 19, 2010 | Dell Latitude D620 Notebook
Is dell latitude D620 laptop have a web cam.
dell latitude D620 do not have webcam
if you want to have a latitude laptop which com with builtin webcam then buy Latitude E series.
Jun 08, 2010 | Dell Latitude D600 Notebook
Why is my Dell Latitude D620 laptop screen turning white?
You'll have to live with it. It's taken damage, it's not repairable, it's only replaceable. My Latitude screen was replaced after only 2 1/2 years.
Nov 02, 2009 | Dell Latitude D620 Notebook
Dell Latitude D620, Black Screen/Power On
It is the backlight! That laptop uses a fluorescent lamp. It is bad.
If you look carefully at the screen, you will see the Windows desktop (or whatebver you are running). It just needs to be lit up.... from the back. Tel them to replace the LCd screen or replace the lamp.
Hope this helps!
Sep 07, 2009 | Dell Latitude D620 Notebook
Dell Latitude D620 Notebook Logo
136 people viewed this question
Alun Cox
