Question about Kenmore Elite 45986 Front Load Washer
Washer problem After loading machine to wash, it suddenly stopped spinning. There was a constant beeping sound and the display screen switching from "H" to "F". I've misplaced my manual, so I am not sure what is causing the trouble. I stopped it entirely twice and started it over & it happened both times Thank you
    Scholar:
  • 65 Answers
Unplug the machine and check the "pintrap" (there is a plug that will catch small items so the dont foul up the washer) It should be in the front of the washer, and have a trap door look, Be AWARE that you WILL release a flood of water by opening this trap door.
Good Luck!
Posted on Jan 24, 2009
  • 641 Answers
Does the machine pump water out ? Open the back panel and see if motor is running ? In case motor is running, check that belt is OK. Let me know with your results and I will do my best to assist you to solve your problem, Good luck !!!
Posted on Jun 04, 2006
SOURCE:
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Feb 20, 2013 | Fisher and Paykel Washing Machines
Displays PFE
The washer will stop during spinning .
Spinning is insufficient. Error display PFE
Is the filter of the drain pump clogged?
Is the drain pump operated?
Did you use the proper amount of detergent?
Is the drain hose placed higher than 1m above floor?
Mar 11, 2012 | Washing Machines
Washer will not go through spin cycle just puts water in tub then will constantly beep
Hi just read your posting.When the machine stops and beeps an error code will appear.In the models with an LCD screen it will tell you what the code is.On machines without an LCD screen a series of lights will light up. The lit lights will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine beeps?Is it the 2nd and 4th or the 3rd and 6th ----etc----?Please reply with additional information on the error code and I can help you rectify this fault.
Jul 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer constantly beeps three beeps
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2008 | Kenmore 46462 Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Fisher and Paykel (Old model) Fresh 5.0
you probably have a foreign object in the pump impellor - the favourite is bits of bra wire
May 05, 2007 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
74 people viewed this question
Sal De
fordexpert
yobo007
yobo007
