Question about Intuit QuickBooks: Pro 2005 for PC
Updating Quickbooks on Vista OS
I purchased a new laptop with MS Vista OS. Loaded my Quickbooks Pro 2005 onto it. Set up my company and tranfered my data from my old laptop using my business net work connection. I can restore from the back up but can not up date on the new Vista laptop, I get an internet connection issue error code C=0. I have tried to establish an internet connection trhough intenet connection set up but keep getting the same error C=) which tell me to restart QB's.
  • iamiceman Oct 20, 2008
    Thanks for the reply, I thought tthat would be the road I would be taking when I purchased the new machine and OS. I asked as many questions about what to expect, realized that I would need to move on and update all my older programs, no matter how well they worked in the past.
  • mikespa May 02, 2009
    same problem, quickbooks pro 2005 with Vista, SP1, 64-bit. I am looking for a cheaper solution than upgrading quickbooks.
    Thanks for your help out there!
    Mike
    Champion:
  • Intuit Expert
  • 237 Answers
There are a couple of things going on here.
First, and most important, Qb 2005 was not designed to run on Vista. Vista was barley even in the planning stages when 2005 was programmed. Vista will probably run it, but in a compatability mode ( pretending to be an older version of Windows), but updating the program will be nightmarish at best because the updates are pointing to files that are either 1) no longer used by Windows or 2) the versions and functionality of the files has changed.
My best advice- restore the backup on an XP box, or get a later version of QuickBooks that will run on Vista.
Posted on Oct 18, 2008
I am trying to install QuickBooks Pro 2007 on a new computer that has Windows Vista Business with SP1, and I had updated Windows, then installed QB but when I imported the company file, QB gave me a...
Why is this happening This issue can occur as a result of uninstalling the Google Desktop installed by Quickbooks on a computer running Microsoft Windows Vista. Launching QuickBooks after uninstalling Google will cause the error message.
Note: This issue is also known to occur with computers that have been upgraded from Windows XP to Windows Vista, where Google Desktop was uninstalled under Windows XP. Both cases would yield the same error message.
How to fix the problem This issue was resolved in the latest release for your version of QuickBooks.
Detailed Instructions Please update your program to the most current release.
just click on that link above then click on the 909ffb0.jpg(update) image on that page.
Oct 27, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Does QuickBooksPro 2005 version run with windows vista
I think Intuit draws the support line at 3 years Even though you have probably registered your product, if there is any trouble with it and the new computer, you will be on your own. I think you would be putting yourself in unnecessary jeopardy to upgrade as you describe at this time. (Your business depends on your computer and software, to operate) You must also be aware of Vista troubles.
If you are in the market for a new computer, you may opt for the new Windows 7 OS and possibly upgrade your Quickbooks at the same time for maximum benefit.
If you have the Vista computer - you already have the Quickbooks, it costs nothing to give it a try. Presumably, you have a XP computer with Quickbooks on it now ... If the Vista - Quickbooks combo doesn't work out you could upgrade the Vista to Windows 7 ... you have nothing to loose in this senerio.
I hope I have provided a little insight for you to consider.
Thanks for using fixya.com
a
Oct 25, 2009 | Intuit QuickBooks: Pro 2005 for PC
How can i make quickbooks 2005 run on a vista laptop?
Here is how to load and activate Quickbooks 2005 on Vista...
First of all, if you already have an activated copy of QuickBooks 2005 on another computer open it and go to "help" "my license information" and print this out so you have the details needed for activating your reinstalled copy (you don't need a fresh activation key and you may have trouble getting one as QuickBooks 2005 is no longer supported by Intuit).
On your new Vista computer, insert the QuickBooks CD but cancel any program install windows that pop up. Go to my computer and find setup.exe on the CD, right click and select the option to "run as administrator"
Once installed, navigate to the QuickBooks folder on your hard drive (typically C:\Program Files\Intuit\QuickBooks) right click on QB32.exe and on the compatibility tab select both Disable visual themes" and "run as adminstrator". Now open this file to run QuickBooks and select "file" "Update QuickBooks" to download and install all updates. QuickBooks will not work properly until you have downloaded the updates, closed and reopened the program.
I had problems with activation but I got around this by unplugging my network cable so that I had no internet connection. If you run QuickBooks without an internet connection, when the screen pops up asking you to "activate" click next and the screen to enter your license details will appear. enter your details (printed out from your previous installation) and you are done. You can restore the internet connection and use QuickBooks 2005 normally.
Andrew
Jul 09, 2009 | Intuit QuickBooks: Pro 2005 for PC
Cannot restore backup Quickbooks onto new laptop
  1. If your backup file is not on your hard disk or in a network folder, insert the CD, USB flash drive, or other storage device in the appropriate drive.
  2. In QuickBooks, go to the File menu and click Open or Restore Company to open the restore wizard.
  3. Click Restore a backup copy (.qbb) and then click Next.
  4. Click Local backup and then click Next. The Open Backup Copy window opens.
  5. If needed, click the Look in drop-down arrow and navigate to the location where you saved the backup file, which has a .qbb file extension (for example, mycompanyname.qbb).
  6. Select the backup file and click Open.
  7. Click Next.
  8. If needed, click the Save in drop-down arrow and navigate to the location where you want to restore the backup file.
  9. Select the backup file, click Save, and respond to any
  10. (Optional) If you're rebuilding your QuickBooks environment, moving your files to a new computer, or need to overwrite all existing files (including changes made since the backups was created),
http://support.quickbooks.intuit.com/support/pages/inproducthelp/Core/QB2K12/ContentPackage/Core/File_Restore/task_data_restore.html
step by step guidance on any more follow
QuickBooks Backup Support
Jun 10, 2009 | Intuit QuickBooks: Premier Editions 2005...
I just purchased a new computer with Windows Vista and now when I try to process a purchase order by sending by email it does not respond
The email capability of the QuickBooks is typically tied to outlook, or outlook express. If the new system does not have MS office installed, then QuickBooks email capability will probably fail.
Mar 10, 2009 | Intuit QuickBooks Pro 2008: Windows
Unable to retrieve company file after closing it
You probably opened an old file. You will need to find the current file that you were using. Use the search and search for all files ending in .QBW
Check the dates they were last used (you don't want the one with the most current date since that was the old file that was opened.)
Feb 17, 2009 | Intuit QuickBooks: Pro 2005 for PC
Quickbooks pro2008- can't seem to update data from a backup
You will need to say "yes". This will install all the data from your business computer so your laptop computer data matches your laptop. The only problem comes if you have made changes on your laptop that you didn't bring over to your business computer. If that is the case, those changes will be lost when you update.
Jan 03, 2009 | Intuit QuickBooks Pro 2008: Windows
Can't open more than one company at a time
Neither of these programs should EVER allow more than one company file to open at time. Each Company file operates as a seperate database.
Dec 18, 2008 | Intuit QuickBooks: Pro 2005 for PC
Quickbooks Pro-restoring a back up from a previous version 2005
If is any help - we have just had the same problem.......had version 5 (very old) of QB
changed computer to Vista and would not work so had to buy Pro 208 for Vista . We really had to get in touch with Quickbooks - they send you a free upgrade kit (disc which is Pro 2006 version (not a fuull version but enogh to get the data over) then you load that on your old machine transfer your data to that then copy that again - then load into Pro 2008 - worked fine for us - have come across a hiccup with VAT - but however I guess we are going to have to give in and phone them after the Bank holiday........apart from that everything was fine.
be brave and phone 'em - tech support was helpful.
May 05, 2008 | Intuit QuickBooks Pro 2008: Windows
2007 quickbook pro
Go to the setup wizard and create a new company/business. Then you can start from the beginning.
Dec 05, 2007 | Intuit QuickBooks: Pro 2005 for PC
Intuit QuickBooks: Pro 2005 for PC Logo
518 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
