Question about Coleman Powermate Powermate 5000W Generator
Lost manual how many quarts of oil does it take to change
  • cobalt_60dwe Oct 28, 2008
    A manual did not come with my generator and I need to know what type of oil to use and how often to change.
When I purchased mine new it came with 1 Quart and I found it to be just a little too much when I filled the crankcase. Check the Oil level stick when adding.
Posted on Oct 27, 2008
How many quarts of oil are used in a 2.3 leader pontiac grand am
Put four litres or quarts in and check the level with dip stick if its down some then add another part litre or quart till its up where it should be.
Jul 01, 2014 | 1995 Pontiac Grand Am
Hi. I have 2007 Mercedes GL450 , Can you help me with oil change and oil filter change.Please tell me How to do it properly? The nearest Mercedes service is over 500 km. thanks alot, A
BEST TO LET DEALERSHIP CHANGE ENGINE OIL.YOU NEED A DEALERSHIP OIL FILTER.YOUR OIL FILTER INSIDE A HOUSING ON FRONT SIDE OF THE ENGINE. CHANGING YOUR OWN OIL NOT HARD.YOU NEED 9 QUARTS OF OIL LOOK INSIDE GLOVECOMPARTMENT FOR OWNERS MANUAL TO SEE WHAT TYPE OF ENGINE OIL YOU NEED TO USE AND HOW MANY QUARTS.IF YOU DONT CHECK READ MANUAL TO SEE WHAT OIL TYPE AND QUARTS YOU NEED. IF YOU BLOW OR DAMAGE THE ENGINE WARRANTY WILL NOT COVER THE ENGINE.FIRST OF ALL TO CHANGE ENGINE OIL YOU CRANK VECHICLE UP LET IDLE FEW MINUTES TO THIN OUT OIL THEN YOU TURN OFF ENGINE. YOU NEED TO RAISE VECHICLE USING THE FACTORY JACK.USE JACK STANDS. LOOK IN OWNERS FOR CAR JACK LIFTING LOCATIONS TO KEEP FROM DAMAGING ROCKER PANELS. AND PLACE A DRAIN PAN UNDER THE OIL PAN. UNDER THE VECHICLE.YOU NEED A WRENCH TO REMOVE OIL PAN DRAIN PLUG.WHEN ALL THE OLD OIL DRAIN OUT IN THE DRAIN PAN.SCREW BACK IN THE DRAIN PLUG TIGHTEN IT DONT OVER TIGHTEN STRIP THREADS.THEN YOU NEED SOCKET TYPE OIL WRENCH YOU USE WITH A 3/8 RATCHET WRENCH REMOVE OIL FILTER HOUSING.PLACE RAGS AROUND THE OIL FILTER HOUSING TO CATCH OIL SPILL. YOU WILL NEED TO GO TO THE DEALERSHIP FOR THE OIL FILTER AND FILTER HOUSING O RINGS. ONCE YOU GET NEW OIL FILTER AND O - RINGS INSTALL THEM IN THE OIL FILTER HOUSING.LOCATED OIL FILLER CAP ON VALVE COVER UNDER THE HOOD.REMOVE OIL FILLER CAP.POUR OIL IN ENGINE USING A FUNNEL.ENGINE HOLDS ABOUT 8.5 TO 9.0 QUARTS OIL. BUT LOOK IN THE OWNERS MANUAL CHECK HOW MANY QUARTS ENGINE NEED.CHECK OIL DIP STICK OIL LEVEL SHOULD BE ON THE FULL MARK ON THE ENGINE OIL DIP STICK.TO BE ON THE SAFE SIDE BUY 10 QUARTS OF OIL FOR A EXTRA.DONT OVER FILL MAKE SURE YOUR OIL LEVEL CORRECT.OIL DRAIN PLUG AND OIL FILTER TIGHT BEFORE CRANKING THE ENGINE.LOOK IN THE OWNERS MANUAL FOR OIL DIP STICK AND LOCATION.
Nov 05, 2010 | 2007 Mercedes-Benz Mercedes Benz Gl 450
How much oil should i put in at an oil change on a 2001 monte carlo 3.4
Hello, this is the oil capacity of your vehicle.
I hope this info is helpfull
  • with filter change
4.1 liters
4.3 quarts
  • without filter change
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
  • 3.4L (LA1)
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
4.1 liters
4.3 quarts
3.75 liters
4.0 quarts
with filter 4.3 quarts
without oil filter 4 quarts
Oct 08, 2010 | Chevrolet Chevy Cars & Trucks
2002 Impala: I do not have a manual...how many quarts of oil wh...
Start with 5 quarts. Start engine for one minute. Shut off and recheck. It should be OK.
May 17, 2010 | 2002 Chevrolet Impala
What is the oil capacity of a mazda 626 LX
2.0L - 3.7 quarts.
2.5L - 4.2 quarts.
Nov 28, 2009 | 1994 Mazda 626
2005 toyota corolla motor oil capacity?
if you have a 1ZZ engine
4.2 quarts, 4.4 quarts with oil filter change
if you have the 2ZZ engine (XRS model) it is
4.4 quarts, 4.6 quarts with oil filter change
NOTE these are updated capacities that reflect changes identified in TSB: TSB-0134-08 issued July 15, 2008.
Your owners manual will reflect a lesser quantity that Toyota has since revised.
Sep 10, 2009 | 2005 Toyota Corolla
Lost my manual how many quarts and what oil is best for an oil change
3.2 quarts 10w30 yamalube 4. any other spec. info. on that bike can be found at www.thefzrarchives.com
Jul 07, 2009 | 1994 Yamaha FZR 600
Oil change
There are two 14mm bolts on both sides (lower) of the motor. Unscrew one or both and drain the oil....Replace with sae 30 or 10w30 oil and should take almost a quart. (Put the bolts back in and tork slightly.) Check oil level.
Jan 11, 2009 | Pramac Storm 5000 Watt Generator
Coleman Powermate Powermate 5000W Generator Logo
278 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
